Revit API Forum
Welcome to Autodeskā€™s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Familt type name change
2 REPLIES 2
abhiw
149 Views, 2 Replies
How to set Element Name in revit api
for floor types
2 REPLIES 2
caroline.gitonga
in reply to: abhiw
Hi @abhiw
You can first check whether the ElementType is eligible for renaming using CanBeRenamed property
Then you can set the ElementType name using the Name property
Carol Gitonga, Developer Advocacy and Support, ADN Open
Yien_Chao
in reply to: abhiw
if you can get the symbol (type), then you can rename the parameter SYMBOL_NAME_PARAM of that symbol.
Forma Design Contest
Rail Community
