Setting Yes/No parameters value through API
Hello! Im trying to import values from an Excel file into my Revit Project. This is the way I am setting the parameters right now but it doesnt do anything to the Yes/No box.
   Parameter p = e.get_Parameter(new Guid("1c8055b5-7eb4-4aba-9da7-91f0255a84d5"));
                    using (Transaction t = new Transaction(doc, "parameter"))
                        t.Start("param");
                        p.Set(0);
                        t.Commit();
Shouldnt the 0 unselect the Yes/No box? Or do I have this mixed up with something else.
Let me know if you need any clarification.
stever66
Is your shared parameter set for "User modifiable" in the shared parameters file?
And  what is "e"?  An element in the model, or a family type?  Since shared parameters are set for each family type, e should contain a family type, not a family instance.  But I'm assuming you have this part right if its working for shared parameters that are a text type.
I don't see anything wrong with the "p.Set(0);" or "p.Set(1);".   That is working for me for yes/no instance parameters.
Hello! Thanks for the reply. I ended up figuring it out, I just rewrote the whole method that part of the code was in and it ended up working. Thanks again for your help!
stever66
I had a heck of a time getting a sample of that code to work too.  The yes/no parameter wouldn't change.  So I tried with a couple of different text parameters.
Still no change.  I kept scratching my head on why something so simple wouldn't work.
Finally realized I had left out one line of code:   t.Commit():
Without that line, nothing in the model changes 🙂
Hahahah I did the exact same thing, took me an hour to figure that one out the hard way.
gdavis479JP
How about you post your fixed code please.
