I want to view the revit file offline in Forge viwer. For this, I need to convert the rvt file to svf or gltf file format. I couldn't find any free open source code to export as svf. Although I managed to export it as a gltf file format, I could not view this gltf file in forge-viewer due to some errors that I could not resolve. Can you share the open source code that I can use to export the Revit file as svf or gltf format without any errors?
The easiest and probably only officially supported method to achieve what you are asking for is to make use of the official Forge translation services:
I was checking the APS supported translated files from .RVT and GLTF is not included
Yes, direct translation from RVT to gltf by APS is not supported. I believe that you can generate gltf from the APS viewer. You can definitely generate it straight from the RVT:
https://duckduckgo.com/?q=revit+gltf+exporter
