Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Export Revit file format as Gltf or Svf and view offline in Forge-Viewer
4 REPLIES 4
oguzkomcu
848 Views, 4 Replies
I want to view the revit file offline in Forge viwer. For this, I need to convert the rvt file to svf or gltf file format. I couldn't find any free open source code to export as svf. Although I managed to export it as a gltf file format, I could not view this gltf file in forge-viewer due to some errors that I could not resolve. Can you share the open source code that I can use to export the Revit file as svf or gltf format without any errors?
Tags (3)
4 REPLIES 4
jeremy_tammik
in reply to: oguzkomcu
The easiest and probably only officially supported method to achieve what you are asking for is to make use of the official Forge translation services:
https://forge.autodesk.com
miguelBW5DE
in reply to: jeremy_tammik
I was checking the APS supported translated files from .RVT and GLTF is not included
jeremy_tammik
in reply to: miguelBW5DE
Yes, direct translation from RVT to gltf by APS is not supported. I believe that you can generate gltf from the APS viewer. You can definitely generate it straight from the RVT:
https://duckduckgo.com/?q=revit+gltf+exporter
MiguelGT17
That was informative!
Good to know that
All the best,
Miguel G.
Rail Community
