Export Revit file format as Gltf or Svf and view offline in Forge-Viewer
oguzkomcu
oguzkomcu
I want to view the revit file offline in Forge viwer. For this, I need to convert the rvt file to svf or gltf file format. I couldn't find any free open source code to export as svf. Although I managed to export it as a gltf file format, I could not view this gltf file in forge-viewer due to some errors that I could not resolve. Can you share the open source code that I can use to export the Revit file as svf or gltf format without any errors?
jeremy_tammik
The easiest and probably only officially supported method to achieve what you are asking for is to make use of the official Forge translation services:
https://forge.autodesk.com
miguelBW5DE
I was checking the APS supported translated files from .RVT and GLTF is not included
jeremy_tammik
Yes, direct translation from RVT to gltf by APS is not supported. I believe that you can generate gltf from the APS viewer. You can definitely generate it straight from the RVT:
https://duckduckgo.com/?q=revit+gltf+exporter
MiguelGT17
That was informative!
Good to know that
All the best,
Miguel G.
