Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Erstausgabe von Plänen mit Index "00"
1 REPLY 1
LC_riederer
118 Views, 1 Reply
Gibt es eine Möglichkeit für die Erstausgabe eines Plans (ohne Index) die aktuelle Änderung auf "00" zu setzen?
(1. Änderung ist dann "01")
Grüße
Thomas
1 REPLY 1
jeremy_tammik
in reply to: LC_riederer
Dear Thomas,
Afaict from your query and screen snapshot, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface. Unfortunately, this is not the best place to ask such a question. Please note that this discussion forum is dedicated to programming Revit using the Revit API. If you are not doing any programming yourself using the Revit API, just using the standard Revit user interface, you will probably get more optimal answers to a question like yours relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
I hope this clarifies. Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik, Developer Advocacy and Support, The Building Coder, Autodesk Developer Network, ADN Open
Forma Design Contest
Rail Community
