Dear Thomas,
Afaict from your query and screen snapshot, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface. Unfortunately, this is not the best place to ask such a question. Please note that this discussion forum is dedicated to programming Revit using the Revit API. If you are not doing any programming yourself using the Revit API, just using the standard Revit user interface, you will probably get more optimal answers to a question like yours relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
I hope this clarifies. Thank you for your cooperation and understanding.
Best regards,
Jeremy
