Edit Light Fixture Asset programmatically
rossen.hristov
rossen.hristov
I have obtained an instance of Autodesk.Revit.DB.Visual.Asset from a Autodesk.Revit.DB.LightNode.  I know that materials for example can be edited with Revit's API by using AppearanceAssetEditorScope, creating a transaction, etc.
My question is, can the same thing be done for lights? Can we edit lights programmatically? I need to change the "intensityValue" and "filterColor" parameters of a light. When I try to set the property value, I get the InvalidOperationException "The asset property is not editable. Asset can be edited only in an edit scope."
How to I get a AppearanceAssetEditorScope for a light? Maybe it is not possible for lights?
In other words, is there a similar example to this one, but for lights: https://www.revitapidocs.com/2019/743c74ba-12de-4d77-a677-325229525955.htm
jeremytammik
All you need in order to instantiate the AppearanceAssetEditScope is the document, isn't it?
I don't see where the problem is.
Ah, looking further, I see the generic EditScope base class, and some derived classes:
https://www.revitapidocs.com/2019/bac11282-3a3b-953e-8bc4-960c62da4946.htm
Do you mean the error message is saying that an edit scope is required for lights, and there is no such thing available?
Can you please submit a minimal reproducible case so we can see what your steps are and what might be wrong?
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Then I can share that with the development team for further analysis if required.
Thank you!
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
rossen.hristov
That is exactly what I mean. Materials have the AppearanceAssetId property and you can create an AppearanceAssetEditScope class and call its Start and Commit methods.
There is no such thing for lights. Or is there? I read your blog post here: https://thebuildingcoder.typepad.com/blog/2017/11/modifying-material-visual-appearance.html
Can we do the same for lights?
My question is very simple, can you edit lights programmatically like you can edit materials. It is a yes/no question.
jeremytammik
Okey-doke. I asked the devteam for you. I did not tell them that you only want a yes or no answer. You might end up being frustrated if they did.
Jeremy Tammik
The Building Coder
rossen.hristov
Thank you!
