intern developer
intern developer
intern developer
Hi ,I am trying to create a face from modellines (which includes both lines and curves) and then using that face as a based for creating a direct shape.are there any option for creating the face?
Thanks so much,
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Try using this below link
https://forums.autodesk.com/t5/revit-api-forum/directshape-from-floor-faces/td-p/7551143
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Hi
 all model line based on the graphic style in whole doc than doing selection.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
From my understanding, it is not possible to create a face directly via API.
First, understand what is face is and how it works in Revit
https://www.revitapidocs.com/2015/e32b3b1f-66fc-57cb-6e1c-aa81d1bf3e63.htm
https://thebuildingcoder.typepad.com/blog/2010/01/faces.html
My suggestion is to create an extrusion element from a set of model lines and from the created element you can get the faces.
https://www.revitapidocs.com/2020/c21472c0-2825-819c-226f-bc8e00ddfec8.htm
Also, check this below link
https://forums.autodesk.com/t5/revit-api-forum/how-to-create-face-from-boundary-loop-curves/td-p/9462158
Naveen Kumar T
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
To get the face
 //Element created by the model line
                Element e;
                Options option = app.Create.NewGeometryOptions();
                option.ComputeReferences = true;
                option.IncludeNonVisibleObjects = true;
                option.View = doc.ActiveView;
                GeometryElement geoElement = e.get_Geometry(option) as GeometryElement;
                foreach(GeometryObject geoObject in geoElement)
                    Solid solid = geoObject as Solid;
                    //The Face Array contains all the faces and from the face array, you can get your required face
                    FaceArray faceArray = solid.Faces;
Naveen Kumar T
Thanks so much,
