Get individual elements within an insterted ifc
klqa_test
klqa_test
After inserting an ifc, i got a box that covers the elements within, i am unable to select the individual elements as everytime i click on it it only selects the entire box, is there a way to code such that i can get the individual elements within that box.
  • IFC
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @klqa_test ,
try using the below code
 //Get the LINKED DOCUMENT
               Document linkedDoc = null;
               foreach(Document d in app.Documents)
                    if(d.Title!=doc.Title && d.Title=="Your Linked Document Title")
                        linkedDoc = d;
                        break;
               //Get the linked element id
                Reference R = uidocument.Selection.PickObject(ObjectType.LinkedElement);
              //Get the linked element from linked document
                Element e = linkedDoc.GetElement(R.LinkedElementId);
Here are some related links
https://thebuildingcoder.typepad.com/blog/2013/09/access-to-individual-elements-in-linked-projects.h...
https://adndevblog.typepad.com/aec/2014/02/how-to-get-the-picked-element-in-the-linked-model.html
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
