Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Dynamo bounding box
7 REPLIES 7
Message 1 of 8
nagybela2000
323 Views, 7 Replies
Dynamo bounding box
Hi there, I have a problem where I want to create a bounding rectangle around the doors in a Revit file. I’ve more or less managed to do that, but unfortunately, the coordinate system doesn’t match. Could you possibly help with what might be worth doing?Additionally, these solids are not being placed in Revit as generic models.
7 REPLIES 7
Message 2 of 8
Hi @nagybela2000
    Bounding box is always parallel to Internal Co-Ordinate system. In image created bounding boxes are correct.
If you need an angled bounding box, then take basis of the family instance and need to create our bounding box by computing geometry.
Hope this will Helps 🙂
Thanks & Regards,
Mohamed Arshad K
Message 3 of 8
Hey!
Dynamo geometry is different from Revit model elements. One is abstract object like a line or a point while other can be described on real world like walls or floors. To make Dynamo geometry touchable in Revit environment you can use ImportInstance.ByGeometry node.
Message 4 of 8
j0hnp
in reply to: nagybela2000
Dynamo now has a node for "BoundingBox.ByMinimumVolume" which is handy for non-axis aligned bounding boxes.
Minimum Volume:
vs Typical Axis Aligned Bounding Box:
john.pierson
expert elite / design technologist / dynamo package creator
designtechunraveled.com
Message 5 of 8
nagybela2000
Message 6 of 8
nagybela2000
Message 7 of 8
nagybela2000
in reply to: j0hnp
I managed to solve it, thank you for your help. My next question is how can I reduce the size of these rectangular prisms by 1-1-1 cm?
Message 8 of 8
nagybela2000
Forma Design Contest
Rail Community
