Document and SynchronizeWithCentral
o_s_
o_s_
I am working with Revit and a document is Workshared.
I am using the following code to update the .rvt file on ACC:
SynchronizeWithCentralOptions synchronizeOptions = new SynchronizeWithCentralOptions();
synchronizeOptions.SetRelinquishOptions(new RelinquishOptions(true));
_document.SynchronizeWithCentral(new TransactWithCentralOptions(), synchronizeOptions);
This part of the code executed successfully, but after opening Autodesk Construction Cloud, the file version remains old and no changes are visible.
Please share an idea if you have one, what could be wrong, my goal is to update the model in ACC.
Thank you!
o_s_
Hello @jeremy_tammik, do you have any ideas related to this problem?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @o_s_ ,
Have you evaluated the optimal manual workflow to achieve the required functionality directly through the Revit UI?
From my understanding, Revit Desktop requires users to explicitly publish the model to reflect changes in Autodesk Construction Cloud (ACC). For cloud worksharing models, users must click "Publish Latest" to update the model in ACC Docs.
UI: https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-A2444193-FCE8-4219-A590-62CA2B8B5C5D
To replicate this via the API, after performing a SynchronizeWithCentral operation, you need to use the Data Management API to publish and update the model in ACC.
API: https://aps.autodesk.com/en/docs/data/v2/tutorials/publish-model/
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
