Revit link Reload from
mgutierrezBM9E9
mgutierrezBM9E9
List<Element> rvtLinks = new FilteredElementCollector(doc).OfClass(typeof(RevitLinkInstance))
.ToList();
foreach (Element link in rvtLinks)
RevitLinkType linkType = link as RevitLinkType;
if (linkType != null)
LinkLoadResult loadResult = linkType.LoadFrom(newModelPath, new WorksetConfiguration());
else if (link.Name.Contains("Record EC -"))
RevitLinkOptions linkOptions = new RevitLinkOptions(false);
LinkLoadResult loadResult = RevitLinkType.Create(doc, newModelPath, linkOptions);
LogTrace($"modelPath directory: {loadResult.ElementId}");
//Document linkDoc = link.GetLinkDocument();
I'm collecting my linked models and I'm interested in the cases where the link as RevitLinkType return null values as those are the ones that I wish to reload from a local path, particularly for the following 2nd listed model:
I have not found a way to achieve that. All I can do so far with null values is to create a new revit link type. However, this does not fix the issue because the outcome is a revit file linked to the root model at a default location. Instead, I only want to reload them since those models have been already moved and aligned at a certain position.
How can I use the "reload from" command for those listed linked models??
scgq425
Hi @mgutierrezBM9E9 :
if you link file change location in main revit file , use this api can reload file and not change the real-location in main revit
 var revitLinkType = doc.GetElement(333166) as RevitLinkType; // deleted a file and let this link vaild and not found
           var status =  revitLinkType.GetLinkedFileStatus();
           if (status == LinkedFileStatus.NotFound)
               var localPath2 = ModelPathUtils.ConvertUserVisiblePathToModelPath(@"D:\B.rvt");
               revitLinkType.LoadFrom(localPath2,new WorksetConfiguration());
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
mgutierrezBM9E9
Thanks for answering me. Indeed, Ishould've used RevitLinkType instead of RevitLinkInstance
