Orientation Issue while creating new sweep geometry from Cable Tray information.
antonio.jambracV7UEE
Message 1 of 1
Hi all,
I’m trying to create a script that takes location, path and dimensions from existing Cable Tray and Cable Tray Fitting families and creates a new sweep rectangular geometry that starts on the bottom of the existing geometry, has same width but is 200mm higher, that will be a place holder for federated model.
I have two issues that I cannot solve: 1. New sweep is correctly created only on existing geometry that has X direction, all others are not correct, please see image below. 2. Exception error occurs, that I can’t find a solution to. If there is no solution, I’ll just skip this geometry and continue with the loop.
If anyone can help, I’ll be grateful.
Here is the code:
namespace TestFile
    [Transaction(TransactionMode.Manual)]
    public class TestClass : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            //Get application and document objects
            UIApplication uiapp = commandData.Application;
            Document doc = uiapp.ActiveUIDocument.Document;
            // Collect all Cable Tray elements in the document
            FilteredElementCollector collectorTray = new FilteredElementCollector(doc);
            ICollection<Element> cableTrays = collectorTray.OfCategory(BuiltInCategory.OST_CableTray).WhereElementIsNotElementType().ToElements();
            // Collect all Cable tray fitting - Bend elements
            FilteredElementCollector collectorFittings = new FilteredElementCollector(doc);
            ICollection<Element> bendTtrays = collectorFittings.OfCategory(BuiltInCategory.OST_CableTrayFitting).WhereElementIsNotElementType().ToElements();
            // Collect all Generic Cable tray place holder previously created
            FilteredElementCollector genericCollector = new FilteredElementCollector(doc);
            IEnumerable<Element> existingPlaceHolder = genericCollector.OfCategory(BuiltInCategory.OST_GenericModel).WhereElementIsNotElementType().ToElements();
            existingPlaceHolder.Where(e => e.get_Parameter(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS).AsValueString().Equals("Tray Place holder"));
            List<Element> existingPlaceHolderList = new List<Element>();
            existingPlaceHolderList.AddRange(existingPlaceHolder);
            //List of all Cable trays
            List<ICollection<Element>> allTrays = new List<ICollection<Element>> { cableTrays };
            allTrays.Add(bendTtrays);
            List<Element> elementTrays = new List<Element>();
            foreach (ICollection<Element> collector in allTrays)
                foreach (Element elementTray in collector)
                    elementTrays.Add(elementTray);
            Transaction trans = new Transaction(doc);
            // Define the color and transparency
            Color color = new Color(255, 0, 0); // Red color
            int transparency = 50; // 50% transparency
            // Create OverrideGraphicSettings
            OverrideGraphicSettings overrideSettings = new OverrideGraphicSettings();
            overrideSettings.SetProjectionLineColor(color);
            overrideSettings.SetSurfaceForegroundPatternColor(color);
            overrideSettings.SetSurfaceTransparency(transparency);
            try
                // Delete previously created sweep geometry
                if (existingPlaceHolderList.Count > 0)
                    trans.Start("Delete old generic cable tray models");
                    foreach (Element element in existingPlaceHolderList)
                        doc.Delete(element.Id);
                    trans.Commit();
                if (elementTrays.Count > 0)
                    foreach (Element cableTray in elementTrays)
                        Category category = cableTray.Category;
                        if (category.Id.IntegerValue != (int)BuiltInCategory.OST_CableTray) // takes in Cable Tray Fitting
                            trans.Start("test");
                            LocationPoint locationPoint = cableTray.Location as LocationPoint;
                            XYZ point = locationPoint.Point; // has same value as origin
                            double rotation = locationPoint.Rotation;
                            Options options = new Options();
                            options.ComputeReferences = true;
                            options.DetailLevel = ViewDetailLevel.Coarse; //Needs to be Coarse to work with ARC, other detail lvl do NOT work
                            GeometryElement geometryElement = cableTray.get_Geometry(options);
                            foreach (GeometryInstance geoInst in geometryElement)
                                if (geoInst != null)
                                    foreach (GeometryObject obj in geoInst.GetInstanceGeometry())
                                        if (obj is Arc)
                                            Arc arc = (Arc)obj;
                                            Curve objCurve = (Curve)obj;
                                            CurveLoop pathLoop = new CurveLoop();
                                            pathLoop.Append(objCurve);
                                            Curve firstCurve = pathLoop.ElementAt(0);
                                            // Get height and width from cable tray
                                            double trayHeight = cableTray.LookupParameter("Tray Height").AsDouble();
                                            double trayWidth = cableTray.LookupParameter("Tray Width").AsDouble();
                                            //get the point to create a plane for the profile.
                                            XYZ xyzFirstpoint = firstCurve.GetEndPoint(0);
                                            // Create Plane
                                            Transform transform = firstCurve.ComputeDerivatives(0, true);
                                            XYZ xyzDirection = transform.BasisX;
                                            Plane profilePlane = Plane.CreateByNormalAndOrigin(xyzDirection.Normalize(), transform.Origin);
                                            double dblHeight = trayHeight + 0.65616797900262469; // increase height by 200mm
                                            double dblWidth = trayWidth;
                                            List<CurveLoop> newloops = new List<CurveLoop> { sweepProfileLoop(dblHeight, dblWidth, profilePlane) };
                                            Solid solid = GeometryCreationUtilities.CreateSweptGeometry(pathLoop, 0, objCurve.GetEndParameter(0), newloops);
                                            DirectShape ds = DirectShape.CreateElement(doc, new ElementId(BuiltInCategory.OST_GenericModel));
                                            ds.SetShape(new List<GeometryObject>() { solid });
                                            doc.ActiveView.SetElementOverrides(ds.Id, overrideSettings);
                            trans.Commit();
                        else
                            LocationCurve location = cableTray.Location as LocationCurve;
                            Curve curve = location.Curve;
                            Line line = curve as Line;
                            XYZ direction = line.Direction;
                            XYZ origin = line.Origin;
                            double length = cableTray.LookupParameter("Length").AsDouble();
                            pathLoop.Append(curve);
                            double trayHeight = cableTray.get_Parameter(BuiltInParameter.RBS_CABLETRAY_HEIGHT_PARAM).AsDouble();
                            double trayWidth = cableTray.get_Parameter(BuiltInParameter.RBS_CABLETRAY_WIDTH_PARAM).AsDouble();
                            // Create Plane
                            //Create a profile which is a rectangle with height and width of the cable tray
                            List<CurveLoop> newloops = new List<CurveLoop> { sweepProfileLoop(trayHeight, trayWidth, profilePlane) };
                            Solid solid = GeometryCreationUtilities.CreateSweptGeometry(pathLoop, 0, curve.GetEndParameter(0), newloops);
                            trans.Commit();
            catch (Exception ex)
                TaskDialog.Show("Exception error", ex.Message);
                trans.RollBack();
                return Result.Failed;
            return Result.Succeeded;
        private CurveLoop sweepProfileLoop(double height, double width, Plane plane)
            double dblHeight = height + 0.65616797900262469; // increase height by 200mm
            double dblWidth = width;
            UV uvPt0 = new UV(0, -height/2) - new UV(dblWidth / 2, 0);
            UV uvPt1 = uvPt0 + new UV(dblWidth, 0);
            UV uvPt2 = uvPt1 + new UV(0, dblHeight);
            UV uvPt3 = uvPt2 - new UV(dblWidth, 0);
            XYZ xVec = plane.XVec;
            XYZ yVec = plane.YVec;
            XYZ xyzPt0 = plane.Origin + plane.XVec.Multiply(uvPt0.U) + plane.YVec.Multiply(uvPt0.V);
            XYZ xyzPt1 = plane.Origin + plane.XVec.Multiply(uvPt1.U) + plane.YVec.Multiply(uvPt1.V);
            XYZ xyzPt2 = plane.Origin + plane.XVec.Multiply(uvPt2.U) + plane.YVec.Multiply(uvPt2.V);
            XYZ xyzPt3 = plane.Origin + plane.XVec.Multiply(uvPt3.U) + plane.YVec.Multiply(uvPt3.V);
            Line l1 = Line.CreateBound(xyzPt0, xyzPt1);
            Line l2 = Line.CreateBound(xyzPt1, xyzPt2);
            Line l3 = Line.CreateBound(xyzPt2, xyzPt3);
            Line l4 = Line.CreateBound(xyzPt3, xyzPt0);
            CurveLoop loop = new CurveLoop();
            loop.Append(l1);
            loop.Append(l2);
            loop.Append(l3);
            loop.Append(l4);
            return loop;
Replies (0)
