Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Debug Revit 2025 pluggin on visual studio 2025.
3 REPLIES 3
pmeigneux
385 Views, 3 Replies
hi,
It is no longer possible to give the name of an executable to debug a Revit plugin. Do you have a solution ?
Philippe.
3 REPLIES 3
pmeigneux
in reply to: pmeigneux
Sorry, visual studio 2022..
Moustafa_K
yep, you need to do it manually. When you create this Debug Profile you will see a new file created named "launchSettings,json" under Properties folder in the solution explorer. compare what you have with this one below, or even you can replace it all with the correct folder path to the Revit.exe file
    "profiles": {
        "Revit2025": {
            "commandName": "Executable",
            "executablePath": "C:\\Program Files\\Autodesk\\Revit 2025\\Revit.exe",
            "commandLineArgs": "/language ENU"
 see if this helps
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
nice3point
Paste it in the .csproj file
<PropertyGroup>
    <StartAction>Program</StartAction>
    <StartProgram>C:\Program Files\Autodesk\Revit 2025\Revit.exe</StartProgram>
    <StartArguments>/language ENG</StartArguments>
</PropertyGroup>
Forma Design Contest
Rail Community
