hi,
It is no longer possible to give the name of an executable to debug a Revit plugin. Do you have a solution ?
Philippe.
Solved by nice3point. Go to Solution.
yep, you need to do it manually. When you create this Debug Profile you will see a new file created named "launchSettings,json" under Properties folder in the solution explorer. compare what you have with this one below, or even you can replace it all with the correct folder path to the Revit.exe file
"profiles": {
"Revit2025": {
"commandName": "Executable",
"executablePath": "C:\\Program Files\\Autodesk\\Revit 2025\\Revit.exe",
"commandLineArgs": "/language ENU"
see if this helps
Paste it in the .csproj file
<PropertyGroup>
<StartAction>Program</StartAction>
<StartProgram>C:\Program Files\Autodesk\Revit 2025\Revit.exe</StartProgram>
<StartArguments>/language ENG</StartArguments>
</PropertyGroup>
