Does someone know where is problem...
need cut wall with family void. But only if the results change the volume of the wall.
public void test(Document doc, IEnumerable<Element> w, IEnumerable<Element> e, ProgressBar pr) { double volumebefore; double volumeafter; foreach (Element q in w) { volumebefore = q.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED).AsDouble(); foreach (Element s in e) { try { using (Transaction tx = new Transaction(doc)) { tx.Start("start transaction"); if (InstanceVoidCutUtils.CanBeCutWithVoid(q)) { InstanceVoidCutUtils.AddInstanceVoidCut(doc, q, s); } // ElementIntersectsElementFilter cutintersectsfilter = new ElementIntersectsElementFilter(s, false); // bool FamilyIntersectsWall = cutintersectsfilter.PassesFilter(doc, q.Id); // if (FamilyIntersectsWall) tx.Commit(); using (Transaction t1 = new Transaction(doc)) { t1.Start("start "); volumeafter = q.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED).AsDouble(); if (volumebefore == volumeafter) { InstanceVoidCutUtils.RemoveInstanceVoidCut(doc, q, s); } else { volumebefore = volumeafter; } t1.Commit(); } } } } catch { } pr.Increment(1); } } }
still make error
The iterator cannot proceed due to changes made to the Element table in Revit's database (typically, this can be the result of an Element deletion).
