Cut wall make error
Cut wall make error
sonicer
Cut wall make error
sonicer
Does someone know where is problem...
need cut wall with family void. But only if the results change the volume of the wall.
public void test(Document doc, IEnumerable<Element> w, IEnumerable<Element> e, ProgressBar pr)
            double volumebefore;
            double volumeafter;
            foreach (Element q in w)
                volumebefore = q.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED).AsDouble();
                foreach (Element s in e)
                    try
                        using (Transaction tx = new Transaction(doc))
                            tx.Start("start transaction");
                            if (InstanceVoidCutUtils.CanBeCutWithVoid(q))
                                InstanceVoidCutUtils.AddInstanceVoidCut(doc, q, s);
                            // ElementIntersectsElementFilter cutintersectsfilter = new ElementIntersectsElementFilter(s, false);
                            // bool FamilyIntersectsWall = cutintersectsfilter.PassesFilter(doc, q.Id);
                            // if (FamilyIntersectsWall)
                            tx.Commit();
                                using (Transaction t1 = new Transaction(doc))
                                    t1.Start("start ");
                                    volumeafter = q.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED).AsDouble();
                                    if (volumebefore == volumeafter)
                                        InstanceVoidCutUtils.RemoveInstanceVoidCut(doc, q, s);
                                    else
                                        volumebefore = volumeafter;
                                    t1.Commit();
                    catch { }
                    pr.Increment(1);
still make error
The iterator cannot proceed due to changes made to the Element table in Revit's database (typically, this can be the result of an Element deletion).
FAIR59
I think, based on the error text you provided, that you pass a null value in list of walls or in the list of cutters. That can be solved by some error checking at the beginning of the method.
		if (q == null || !q.IsValidObject) continue;
		if (!InstanceVoidCutUtils.CanBeCutWithVoid(q)) continue;
                    if ( s ==null || !s.IsValidObject) continue;
                    if ( InstanceVoidCutUtils.InstanceVoidCutExists(q,s)) continue;
                    try
       			    tx.Commit();
That will solve the issue, but leaves the question why it occurs.
Suggestions:
  • Are you creating the cutters in the same command?  If so, is the FamilySymbol Active?
  • try a document.Regenerate() before calling the method.
sonicer
dont know where is problem ...if I cut the wall and then check if the volume is changing then I give same volume as before cut...
I used also doc.regenerate().
FAIR59
Can you make the cut manually using the same cutting family?
If that's true, then I think the problem is somewhere in the rest of your code.
Using the same layout I made a command (Revit 2016) that works. { select 1 or more walls, 1 or more cutting instances and run command}
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class Cmd_CutWalls : IExternalCommand
        StringBuilder sb = new StringBuilder();
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIDocument uiDoc = commandData.Application.ActiveUIDocument;
            Document doc = uiDoc.Document;
            Autodesk.Revit.UI.Selection.Selection sel = commandData.Application.ActiveUIDocument.Selection;
            List<Element> walls = new List<Element>();
            List<Element> cutters = new List<Element>();
            foreach (ElementId id in sel.GetElementIds())
                Element e = doc.GetElement(id);
                if (e is Wall) { walls.Add(e);}
                else { cutters.Add(e); }
            double volumebefore = 0;
            double volumeafter =0 ;
            using (TransactionGroup tg = new TransactionGroup(doc, "cut walls"))
                tg.Start();
                foreach (Element q in walls)
                    sb.AppendLine(string.Format("wall  {0}", q.Id));
                    foreach (Element s in cutters)
                        if (s == null || !s.IsValidObject) continue;
                        if (!InstanceVoidCutUtils.IsVoidInstanceCuttingElement(s))
                            sb.AppendLine("      instance is not family with unattached voids for cutting");
                            continue;
                        sb.AppendLine(string.Format("   cutter  {0}", s.Id));
                        if (InstanceVoidCutUtils.InstanceVoidCutExists(q, s))
                            sb.AppendLine("      instance is already cutting wall");
                            continue;
                        try
                                tx.Commit();
                                t1.Start("start ");
                                sb.AppendLine(string.Format("      volume_before: {0}    volume_after: {1}", volumebefore, volumeafter));
                                if (Math.Abs(volumebefore - volumeafter) < 0.0001)
                                    sb.AppendLine("        not cutting, cut removed");
                                else
                                    sb.AppendLine("        cut succeeded");
                                t1.Commit();
                        catch (Exception ex)
                            TaskDialog.Show("catch", ex.ToString());
                            return Result.Failed;
                    sb.AppendLine();
                tg.Assimilate();
            TaskDialog.Show("debug", sb.ToString());
            return Result.Succeeded;
sonicer
i found a problem ..
my mistake.
change to
volumebefore = q.get_Parameter(BuiltInParameter.HOST_VOLUME_COMPUTED).AsDouble();
