VS 2015 add reference
Moshe-A
Mentor Mentor
Moshe-A
Hi Guys
Need a quick help here, please
have 1 solution and i would like to give support to the same app for R2015 - R2018?
tried to add reference to RevitAPI.dll + RevitAPIUI.dll and the VS only remembers the last set
Moshe
RPTHOMAS108
As far as I know separate configurations don't allow you to have separate references.
This is a bit odd and limiting considering the existence of conditional compilation statements and compilation constants. It would be nice to have a single solution file with code blocks set for different Revit versions.
Troy_Gates
Here is a great write up with examples on how to have a single solution with multiple Revit versions. I have been doing this same method for several years and it works great.
http://archi-lab.net/how-to-maintain-revit-plug-ins-for-multiple-versions/
Moshe-A
wow troy, this looks very sophisticate to me and i still do not understand what to do with postBuildCode.cs and how implment it
does this create only 1 addin (dll) for all revit version i need?
Moshe-A
dispite that,  i will face the challange tonight
Moshe-A
Troy,
wow thank you
this is wonderful i made it. the only problem i left with is the assembly name i want each Revit version to have a different name (e.g myapp201X.dll)
since my application is wraped up in inno setup program and all the dll's will be installed in my application folder
the only file that need to be send to Addin folder is the myapp.addin (this is been edit by inno setup to load the excat dll needed)
can i have different assembly name?
Moshe
Moshe-A
ok found the solustion on the web
thanks you all
