Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Customise Ribbon
4 REPLIES 4
344 Views, 4 Replies
Customise Ribbon
How might I remove/declutter the Ribbon of commands I do not want used - either by all, or select, people. In other words, is there an Autocad-.cui-like interface to customise user workspaces beyond what is presently presented in the options dialog? Preferably without tinkering in the API
I'm looking at:
REMOVE
Import CAD
Explode .dwg
HIDE
Ramp
Soffit
Shaft
Insulation
Text
Purge
RESTRICT
In-Place Mass
Line patterns
Line styles
Object styles
Project Parameters
Project Units
Project Information
Location
Coordinates
Position
Manage Links
Phases
ENABLE PERSONAL PREFERENCE
Browser Organisation (retained at a local model / user revit.ini level and not commited back to central)
Properies & Browser dialog locations
Tags (2)
4 REPLIES 4
alan.quinn
Currently this is not possible in Revit and I'm not sure if it will ever be possible but if you like I’d suggest leaving feedback at the below link. Information gathered is used to improve the application. Product Contact Link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thanks for posting.
As @alan.quinn said, it's not possible on the product, but just to be complete, you can do some customization via API (although you said you don't want it).
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Hi Augusto,
with the Revit API, you can only add buttons but not remove them, especially not the built-in buttons.
As far as I understand, the user wants to reduce the GUI.
There are certain ways to modify existing buttons (remove, disable, hide), but all of them are unsupported,
meaning you can indeed reduce the content of the Ribbonbar, but only using hacks.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
alan.quinn
If you are all set please mark this one as Accepted. Thanks again for posting.
Forma Design Contest
Rail Community
