- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
While searching through the API, I found this snippet:
public Workset CreateWorkset(Document document) { Workset newWorkset = null; // Worksets can only be created in a document with worksharing enabled if (document.IsWorkshared) { string worksetName = "New Workset"; // Workset name must not be in use by another workset if (WorksetTable.IsWorksetNameUnique(document, worksetName)) { using (Transaction worksetTransaction = new Transaction(document, "Set preview view id")) { worksetTransaction.Start(); newWorkset = Workset.Create(document, worksetName); worksetTransaction.Commit(); } } } return newWorkset; }
But when using the Revit SharpDevelop I can't run the macro in the macro manager, it just doesn't show up as a macro but there are also no errors during build. Am I doing something wrong?
