Creating Workset
Creating Workset
Avaris.
Advisor Advisor
Creating Workset
Avaris.
While searching through the API, I found this snippet:
public Workset CreateWorkset(Document document)
    Workset newWorkset = null;
    // Worksets can only be created in a document with worksharing enabled
    if (document.IsWorkshared)
        string worksetName = "New Workset";
        // Workset name must not be in use by another workset
        if (WorksetTable.IsWorksetNameUnique(document, worksetName))
            using (Transaction worksetTransaction = new Transaction(document, "Set preview view id"))
                worksetTransaction.Start();
                newWorkset = Workset.Create(document, worksetName);
                worksetTransaction.Commit();
    return newWorkset;
But when using the Revit SharpDevelop I can't run the macro in the macro manager, it just doesn't show up as a macro but there are also no errors during build. Am I doing something wrong?
aignatovich
Hi!
You should create macro, see for example https://www.augi.com/articles/detail/getting-started-with-revit-macros named CreateW (in my case, you may use your own names and call this method like this:
	public void CreateW() // this is auto generated
		CreateWorkset(this.Document);
        private Workset CreateWorkset(Document document)
            return newWorkset;
When I make this as a macro I get the error:
Error CS0118: 'Workset' is a 'namespace' but is used like a 'type' (Line 43,12)
I followed the macro creation and copy pasted your solution text. Is this a new thing since 2017?
Thanks for the patience, I am new to macros
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace Workset
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("3A376C2A-1AA0-4769-A7D3-C35FBE1395E3")]
	public partial class ThisApplication
		private void Module_Startup(object sender, EventArgs e)
		private void Module_Shutdown(object sender, EventArgs e)
		#region Revit Macros generated code
		private void InternalStartup()
			this.Startup += new System.EventHandler(Module_Startup);
			this.Shutdown += new System.EventHandler(Module_Shutdown);
		#endregion
             return newWorkset;
