Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Create RebarFromCurves_Dynamo
5 REPLIES 5
duongphong29
2639 Views, 5 Replies
Hi!
I am trying to create rebar for beams by drawing curves in Dynamo.
But I don't know why when I join 3 curves into 1 polycurve the Create.FromCurve node doesn't work (picture 2)
Anyway, when I put in 3 curves, it turns out to be 3 seperated rebar like in picture 1.
I also attach my dynamo file. Can some one please helps me out.
Labels (3)
5 REPLIES 5
Hey,
Maybe this thread on the Dynamo Forum can help you:
https://forum.dynamobim.com/t/to-bsplinecurve-not-implemented/25454
Kind regards.
Github:
https://github.com/franpossetto
I have fixed my problems.
Turns out because  I am using Revit 2021 and I created rebar by using nodes from packages Structural Design.
I changed to package Structural Rebar and updated to version 2.0.2 then everything works great.
in reply to: duongphong29
I've came across your post while I was trying to resolve the same problem.
I'm trying to create rebar by curve using Rebar.byCurve node from DynamoRebar package. Everything works fine except from the bar creation. I have a U-shape polycurve but everytime I run my dynamo script it puts rebar separately on every line instead of creating one continous line. I suspect the package problems.
In your case you said that solution was to download the Structural Rebar package but I cannot find it. I'm also using Revit 2021.
I'm attaching my script, maybe you could take a look at my approach.
I'll appreciate any help.
Best regards,
Szymon Niebora
Hamid.SAJJADI
" Rebar.byCurve " is normaly used for longitudinal rebars,
For the stirrups, you have to use "Rebar.bycurves" , (plurial)
Certainly it fixs your problem.
Cordialement
snazki
You should use "Rebar.by Curves" node instead of "Rebar.by curve node"
Forma Design Contest
Rail Community
