Get location of Assembly DLL in Revit 2025 / .net 8
stj4M66M
stj4M66M
Hi
I would like to get the location of the DLL file, because I need to read another file placed in the same folder.
In .net framework 4.8 I've used Assembly.GetExecutingAssembly().Location, but it return an empty string in .net 8.
I also tried AppDomain.CurrentDomain.BaseDirectory but it returns the directory of Revit.exe.
Any suggestions?
jeremy_tammik
Speed_CAD
Hi stj4M66M,
CodeBase may be deprecated in future versions of .NET, but it still works on .NET 8, try this:
string location = new Uri(System.Reflection.Assembly.GetExecutingAssembly().CodeBase).LocalPath;
Mauricio Jorquera
stj4M66M
Thanks.
Is working.
I already tried that earlier, but it returned "C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.7\System.Private.CoreLib.dll". Now I learned, that it was because I ran the plugin from the Add-in Manager. I didn't know that it executes the code in another way.
When I run the code via Add-in/ribbon button I am able to get the assembly location.
Thank you for your help.
Regards Steffen
esatis
I have same problem. Any idea how to get assembly location when running from Add-in Manager?
ricaun
Add-in Manager probably is loading the your dll file in the memory using something like this:
byte[] assemblyBytes = File.ReadAllBytes("YourAssembly.dll");
Assembly loadedAssembly = Assembly.Load(assemblyBytes);
This make the assembly in the memory instead of a physical file, and make the location empty and the physical file does not lock in the process.
That how it works. 🤘
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
stj4M66M
I havn't found a solution. I ended up creating a ribbon-button.
