Create rebar from lines and arc curve
atir5UTNF
atir5UTNF
Is possible to create rebar from straight line segment/s and arc curve segment?
jeremy_tammik
I am not an expert on rebar, but searching the Internet seems like a good place to start:
https://duckduckgo.com/?q=revit+rebar+create+from+curve
pyaezone
Which method are you using to create rebar? CreateFromCurves (or) CreateFromCurvesAndShape (or) CreateFreeForm?
There are geometries that aren't allowed in rebar shape families.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-054A2971-BA2D-46BF-A508-3D805F1C2666
You might wanna use CreateFreeForm method.
Also refer to the following post.
https://forums.autodesk.com/t5/revit-structure-forum/can-t-convert-sketch-to-rebar-shape/td-p/921079...
atir5UTNF
Thannks!
This is what I needed.
benlHWGFE
Is this ever going to change? We need to detail a lot of rebar shapes that end in an arc. These need to be scheduled. Is there another way to schedule these bars? Freeform just has the A paramenter for the overall length and that's it.
