Worsets Parameter
Worsets Parameter
Cesar.mayorine
Worsets Parameter
Cesar.mayorine
hello everyone!
is there any method (c# API) by which you can change the attributes of a workset, for example "IsEditable" from true to false?
jeremy_tammik
You can use all the non-read-only properties on the Workset class:
https://www.revitapidocs.com/2023/437250cb-c87d-4492-9a53-bde8605012f4.htm
The read-only properties cannot be modified directly. They are calculated from other relationships and dependencies. To understand how to change their values, you best bet will be to study the end user interactions and best practices for handling worksets. The API adds nothing more, it just reflect the existing UI functionality.
Cesar.mayorine
Thank you for your reply!
