Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Create angular dimension with 3 references and equal angles
m.walterN99B3
m.walterN99B3
Is there a way in the API or maybe a workaround to create an angular dimension with equal angles between 3 model lines?
NewAngularDimension only accepts 2 references:
public Dimension NewAngularDimension(
	View view,
	Arc arc,
	Reference firstRef,
	Reference secondRef
longt61
which version of Revit API do you use?  As far as I know, Revit API 2022 has already supported this in AngularDimension class.
m.walterN99B3
I use Revit 2016-2026.
In the documentation for Revit 2022-2026 there is no method in FamilyItemFactory Class named NewAngularDimension with 3 references:
https://www.revitapidocs.com/2026/5c2584a9-34e2-3b37-0ceb-64efc71c5dd0.htm
