AWSSDK with Revit 2025
mizrachi_amir
mizrachi_amir
My plugin is using AWSSDK.DynamoDBv2 nuget package.
This works fine for Revit up to version 2024 (with AWSSDK version 3.3.0).
Even though I tried to update the package version to the latest (I thought maybe this will be working in Revit 2025) - it seems like Revit by default loads version 3.3.0 regardless of the package I am trying to force it to use for Revit 2025.
Printing this always yields 3.3.0, regardless which package is actually installed:
var awsCore = Assembly.GetAssembly(typeof(Amazon.Runtime.AmazonServiceClient));
var awsDynamoDB = Assembly.GetAssembly(typeof(Amazon.DynamoDBv2.AmazonDynamoDBClient));
Debug.WriteLine($"Loaded AWS SDK Core Version: {awsCore?.GetName().Version}");
Debug.WriteLine($"Loaded AWS SDK DynamoDB Version: {awsDynamoDB?.GetName().Version}");
Questions:
1. Someone has any experience with Revit 2025 and DynamoDBv2 package?
2. Which package version should be working in Revit 2025?
3. How can I install multiple versions of that package so that version 3.3.0 will be loaded to Revit 2021-2024 while latest version will be loaded to Revit 2025?
BTW, in my bin Debug2025 folder I do see the correct package version in Revit 2025 but in runtime it seems like Revit loads by default 3.3.0.
Thank you!
TripleM-Dev.net
For Revit 2025 you need the version that supports .NET 8 (could also be named .NET Core 8)
Revit 2021-2024 uses .NET Framwork 4.8
Is this a package for Revit Dynamo? (not familiar with AWSSDK.DynamoDBv2)
- Michel
mizrachi_amir
I am aware to the .NET version for Revit 2025, and actually my plugin do work in Revit 2025.
The issue is with the AWSSDK from Amazon (unrelated to Revit Dynamo).
As I said it seems like Revit (in all versions) be default loads version 3.3.0 and I assume that in Revit 2025 I need a different package version as this specific versios simply does not work in Revit 2025.
jeremy_tammik
You can look at the Dynamo source code and determine what AWSSDK version is loaded. I see that the current nuget packagen supports .NET 8:
mizrachi_amir
Thank you, @jeremy_tammik.
But the issue I am encountering with is that Revit loads an older version by default (version 3.3.0), no matter what AWS DynamoDBv2 nuget package appear in my project.
How can I force Revit to load a specific version other than its default?
jeremy_tammik
Oh dear. If Revit loads it by itself, you either have to live with that or isolate your add-in's .NET environment. In Revit 2025, this is entirely possible, as explained  here, on RevitLookup Dependency Isolation Ends DLL Hell:
mizrachi_amir
Cursor solved my issue by forcing Revit to use a specific dynamodbv2.dll for Revit 2025 and above.
Whoever encounters this similar issue - feel free to contact me.
