Change Revit Link Display Settings and Design Options using API
asattar.md
Message 1 of 17
asattar.md
We are developing a plugin that automatically selects the Design options for all the linked models based on an external file (that external file is not even Revit, it could just be a JSON file that lists the design options for linked files).
Basically, we'd like to automate the following screens:
  1. Clicking  Edit Visibility/Graphics Override
  2. Navigate to "Revit Links" and for each Link, do the following steps:
     a.  Click "By Host View"
     b.  Select "Custom" (Screenshot 1)
     c.  Navigate to "Design Options"
     d.  For each Design Option Set, select the Design Option from the external file (JSON). (Screenshot 2)
We have seen APIs for Categories and Filters, but we weren't able to find an API for Revit Links. We'd be grateful if someone could point us in the right direction.
Screenshot 1: Selecting Custom for Revit Link Display Settings
Screenshot 2: Selecting Design Option for a Design Option Set.
Replies (16)
Message 2 of 17
jeremytammik
Sorry, off-hand I am not aware of any solution for your problem.
All I can do is sit down and research and debug just like you.
I wish you the best of luck and hope you find a solution.
I would love to hear about it when you do!
Thank you!
If worst comes to worst, you know that you can simulate every single user action using the Windows API and the .NET Automation library, don't you?
The Building Coder published a number of posts on that topic that may help:
http://thebuildingcoder.typepad.com/blog/automation
I hope this helps.
Cheers, Jeremy.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 17
asattar.md
Thanks for replying to this! We have gone through the API extensively (and we're still exploring it in the hope of finding something). We actually have some crude UI automation using Coded UI tests as a fallback. Thanks for replying again!
Message 4 of 17
Hi jeremy, I am struggling with somewhat the same question. I want to change the presentation of linked files by using the Visibility/graphics dialog to set the linked files on "BY Linked view" and selecting a desired view.
Can you put the question to make the Revit Link Display settings available in the API on the Revit wishlist ?
Message 5 of 17
Same here...
I'm currently trying to access / filter the selection via the Windows API (no luck yet)
have you gotten anything yet?
Message 6 of 17
Hi there,
Were you ever able to make progress controlling Revit Links in the way you proposed? I just posted a similar question here:
https://forums.autodesk.com/t5/revit-architecture-forum/rvt-link-display-settings-batch-changes/td-p...
Thanks!
Spencer
Message 7 of 17
roman.golev
Hey guys, it's been 7 years since this issue had been quered. Is there any information if it's going to be implemented in Revit API or not? Feels like nobode really cares abouts that since it had recieved only 4 likes...
 @asattar.md did you manage to succeced with implementation using Windows API?
Kind regards, Roman Golev.
Message 8 of 17
asattar.md
@roman.golev I don't think we were able to. We had to resort to UI automation iirc.
Message 9 of 17
Mustafa.Salaheldin
@jeremytammik is there any update regarding manipulating RVT Links V/G in view template using API?
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 10 of 17
jeremy_tammik
Hi Mustafa,
the best way to find out and also to drive this forward os to check out the corresonding wish list item in the Revit Idea Station and, better still, join the Revit Preview forum and ask the developers there directly.
Cheers
Jeremy
Message 11 of 17
Mustafa.Salaheldin
Yes, I checked the Wishing list 😁
I wished I never went there 😁
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 12 of 17
Mustafa.Salaheldin
I managed to find the solution but I receive a very strange message if I tried to set the display mode to anything other than ByHostView:
I think with a little tweak, it can be possible. I tested this on Revit 2024.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 13 of 17
Mustafa.Salaheldin
@jeremy_tammik The answer is here, it is just not working for some reason. Can you please check with the development team, maybe this needs to be reported as a bug.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 14 of 17
Mustafa.Salaheldin
How can we make use of these two BIP's:
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 15 of 17
Mustafa.Salaheldin
@jeremy_tammik any update please?
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 16 of 17
Mustafa.Salaheldin
The good news is now Revit 2026 API allows VG overrides for RVT Links in View Templates.😎
The bad news is it is still not allowing overriding Half tone and Underlay for RVT Link instances in VT. 🤣
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 17 of 17
nizar71
Community Visitor
Community Visitor
Thank you @Mustafa.Salaheldin for the hint,
I've managed to make it working in Revit 2024 using a dictionary to map the views with linked views.
I hope it helps or gives an inspiration.
Nizar.
using System;
using System.Linq;
using System.Collections.Generic;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
[Transaction(TransactionMode.Manual)]
public class SetLinkViewOverrides : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
        UIApplication uiApp = commandData.Application;
        UIDocument uiDoc = uiApp.ActiveUIDocument;
        Document doc = uiDoc.Document;
        // Define dictionary: { Host View Name → Linked View Name }
        Dictionary<string, string> viewMapping = new Dictionary<string, string>
            { "Site Plan", "Linked Site Plan" },
            { "Second Floor", "Linked Second Floor" },
            { "First Floor", "Linked First Floor" }
            // Add more mappings as needed
        // Collect all Revit link instances
        List<RevitLinkInstance> linkInstances = new FilteredElementCollector(doc)
            .OfClass(typeof(RevitLinkInstance))
            .Cast<RevitLinkInstance>()
            .ToList();
        int successCount = 0;
        using (Transaction trans = new Transaction(doc, "Set Linked Views"))
            trans.Start();
            // Iterate through all views in the document
            foreach (View hostView in new FilteredElementCollector(doc)
                     .OfClass(typeof(View))
                     .Cast<View>()
                     .Where(v => !v.IsTemplate)) // Ignore templates
                // Check if this view has a mapping
                if (!viewMapping.TryGetValue(hostView.Name, out string linkedViewName))
                    continue; // Skip if no linked view is assigned
                foreach (var linkInstance in linkInstances)
                    Document linkDoc = linkInstance.GetLinkDocument();
                    if (linkDoc == null) continue; // Skip unloaded links
                    // Find the specified linked view
                    View linkedView = new FilteredElementCollector(linkDoc)
                        .Cast<View>()
                        .FirstOrDefault(v => !v.IsTemplate && v.Name == linkedViewName);
                    if (linkedView != null)
                        // Apply "By Linked View" override
                        SetLinkViewOverride(hostView, linkInstance.Id, linkedView.Id);
                        successCount++;
            trans.Commit();
        TaskDialog.Show("Result", successCount > 0
            ? $"Linked views applied to {successCount} views."
            : "No linked views were set. Check view names in dictionary.");
        return Result.Succeeded;
    /// <summary>
    /// Sets the visibility override of a linked model in a view to "By Linked View".
    /// </summary>
    private void SetLinkViewOverride(View hostView, ElementId linkElementId, ElementId linkedViewId)
        RevitLinkGraphicsSettings settings = new RevitLinkGraphicsSettings
            LinkVisibilityType = LinkVisibility.ByLinkView,
            LinkedViewId = linkedViewId
        hostView.SetLinkOverrides(linkElementId, settings);
