Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Copying linked elements in wrong location
8 REPLIES 8
Message 1 of 9
ICON-MIJ
360 Views, 8 Replies
Hi All,
following a discussion here. im experiencing odd result . The copied elements are not in the same location as the linked mo...
Reference reference = uidoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element);
                RevitLinkInstance revitLinkInstance = doc.GetElement(reference) as RevitLinkInstance;
                Document sourcedocument = revitLinkInstance.GetLinkDocument();
                ICollection<ElementId> linkedElements = new FilteredElementCollector(sourcedocument)
                .OfCategory(BuiltInCategory.OST_VolumeOfInterest)
                .WhereElementIsNotElementType().ToElementIds();
                CopyPasteOptions copyOptions = new CopyPasteOptions();
                copyOptions.SetDuplicateTypeNamesHandler(new CopyUseDestination());
                ElementTransformUtils.CopyElements(sourcedocument, linkedElements,doc, revitLinkInstance.GetTotalTransform(), copyOptions);
8 REPLIES 8
Message 2 of 9
Mohamed_Arshad
in reply to: ICON-MIJ
HI @ICON-MIJ
Kindly use Transform.Identity instead of GetTotalTransform()
ElementTransformUtils.CopyElements(sourcedocument, linkedElements,doc, Transform.Identity, new CopyPasteOptions());
Hope this will Helps 🙂
Thanks & Regards,
Mohamed Arshad K
Message 3 of 9
ICON-MIJ
in reply to: Mohamed_Arshad
I tried and still the same result
Message 4 of 9
Mohamed_Arshad
Have you tried by removing the CopyPasteHandler?, Create Directly by new CopyPasteOptions().
And Which element you're trying to copy?
Thanks & Regards,
Mohamed Arshad K
Message 5 of 9
ICON-MIJ
I tried the following:
1. Copy without handler
2. Manual Copy form document to document via UI
3. Via Dynamo
and none works for me...very strange..I'm copying scope boxes
Message 6 of 9
Mohamed_Arshad
Which Element you're trying to copy?
Thanks & Regards,
Mohamed Arshad K
Message 7 of 9
ICON-MIJ
Scopeboxes
Message 8 of 9
ICON-MIJ
It's working on other elements such as walls, floors, furnitures but not on Scopeboxes
Message 9 of 9
Mohamed_Arshad
No For me its Wokring Fine. I use same code only.
Reference GIF:
            Reference reference = revitUIDoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element);
            .ToElementIds();
            using (Transaction createTransaction = new Transaction(doc, "Create Transaction"))
                createTransaction.Start();
                ElementTransformUtils.CopyElements(sourcedocument, linkedElements, doc, Transform.Identity, new CopyPasteOptions());
                createTransaction.Commit();
Thanks & Regards,
Mohamed Arshad K
Rail Community
