Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
"Unexpected tab" error
3 REPLIES 3
denisyukJ
389 Views, 3 Replies
denisyukJ
Trying to make a simple tab, but faced with an error.
Here is my code:
#region Namespaces
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Linq;
using System.IO;
using System.Reflection;
#endregion
namespace YYY
    internal class App : IExternalApplication
        public Result OnStartup(UIControlledApplication a)
            string tabName = "PERIR";
            string panelName = "Info";
            a.CreateRibbonPanel(tabName);
            var panel = a.CreateRibbonPanel(tabName, panelName);
            var button1 = new PushButtonData("Info", "b1", "C:\\Users\\denisyuk\\Desktop\\RevitApiTest\\YYY.dll", "YYY.Command");
            button1.ToolTip = "TT";
            button1.LongDescription = "This is TT";
            var btn1 = panel.AddItem(button1) as PushButton;
            return Result.Succeeded;
        public Result OnShutdown(UIControlledApplication a)
Nothing special just stuck on this.
UPD: I set AssemblyName hardcoded because I use virtual michine to make a build and place it as well as addin file to correspondng directories manually.
Here is my code:
#region Namespaces
using System;
using System.Linq;
using System.IO;
#endregion
namespace YYY
3 REPLIES 3
Mohamed_Arshad
in reply to: denisyukJ
Mohamed_Arshad
HI @denisyukJ
you're not creating a tab, Twice time you have created panel. Check Line No. 24 and 25.
In Ln No.24 change to a.CreateRibbonTab(tabName);
Hope this will Helps 🙂
Thanks & Regards,
Mohamed Arshad K
HI @denisyukJ
Thanks & Regards,
Mohamed Arshad K
jeremy_tammik
jeremy_tammik
You are calling CreateRibbonPanel twice over. Revit probably does not like that.
denisyukJ
denisyukJ
Sorry for my inattention. Shame on me. 😣
