Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Copying Linked Elements
1 REPLY 1
jmyr
272 Views, 1 Reply
jmyr
Hi All,
I'm trying to copy from linked document with the following code, but unfortunately it's creating multiple element types. Ay idea what's happening?
 FilteredElementCollector links = new FilteredElementCollector(doc)
                    .OfClass(typeof(RevitLinkInstance));
                Document linkedDoc = links.Cast<RevitLinkInstance>().FirstOrDefault().GetLinkDocument();
                RevitLinkInstance revitLinkInstance = links.Cast<RevitLinkInstance>().FirstOrDefault();
                ElementFilter elementFilter = new ElementCategoryFilter(BuiltInCategory.OST_PipeCurves);
                ICollection<ElementId> ids = new FilteredElementCollector(linkedDoc).WherePasses(elementFilter).ToElementIds();
                CopyPasteOptions copyOptions = new CopyPasteOptions();
                copyOptions.SetDuplicateTypeNamesHandler(new copyHandler());
                if (ids.Count == 0)
                    TaskDialog.Show("Copy Paste", "The link does not contain the specified elements.");
                else
                    Transaction targetTrans = new Transaction(doc);
                    targetTrans.Start("Copy and paste linked elements");
                    Transform transform = revitLinkInstance.GetTotalTransform();
                    IList<ElementId> copiedElements = ElementTransformUtils.CopyElements(linkedDoc, ids, doc, transform, copyOptions).ToList();
                    targetTrans.Commit();
        public class copyHandler : IDuplicateTypeNamesHandler
            public DuplicateTypeAction OnDuplicateTypeNamesFound(DuplicateTypeNamesHandlerArgs args)
                return DuplicateTypeAction.UseDestinationTypes;
Thank you.
Hi All,
                if (ids.Count == 0)
                else
Thank you.
1 REPLY 1
naveen.kumar.t
in reply to: jmyr
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @jmyr ,
Did you check what is inside this "Ids"?
I think the code you used, gets the element types, not the elements. That's why you have multiple element types.
To get the elements present inside the linked document, please use the below code
 FilteredElementCollector collectoer = new FilteredElementCollector(linkedDoc).WherePasses(elementFilter).WhereElementIsNotElementType();
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Hi @jmyr ,
Naveen Kumar T
