Hi Guys I wanted to ask how can I change the slope arrow in the floor From "Slope" to "height At Tail", if that is possible how can I edit the parameters "Height offset at tail" && "height offset at Head" .
Keep in mind that the floor is alread created and I have the slopearrow also created .
Floor floor = Floor.Create(doc, new List<CurveLoop> { c1 }, floortype.Id, lev.Id, true, Slopearrow, 0)
Solved by naveen.kumar.t. Go to Solution.
I don't know whether this is possible programmatically, or how to achieve it in the UI either. One effective approach that you can take yourself to find out immediately is to perform the required modification manually in the end user interface and analyse the resulting API-accessible differences between the states before and after in the Revit database using RevitLookup and other database exploration tools:
Hi @jeremy_tammik ,
in the UI you just double click on the floor and select the slopearrow drawn inside the floor. I just want to change the Parameter Type "Slope" to "Height AT Tail" only and edit the parameters inside. are you sure there is no way to edit them ?
Hi @ahmadkhalaf7892 ,
Yes, editing the slope arrow after creating a floor element is possible via Revit API.
First, you need to tell Revit whether you want to use "Height at Tail" or "Slope".For this you need to use BuiltInParameter.SPECIFY_SLOPE_OR_OFFSET
slopeArrow.get_Parameter(BuiltInParameter.SPECIFY_SLOPE_OR_OFFSET);
//"0" means height at tail
//"1" means slope
Here is the sample code for Height at tail
Floor floorElement;
Sketch sketch=doc.GetElement(floorElement.SketchId) as Sketch;
IList<ElementId> allElements = sketch.GetAllElements();
foreach(ElementId eid in allElements)
Element e = doc.GetElement(eid);
if(e.Name.Contains("Slope Arrow"))
double startValue;
double endValue;
e.get_Parameter(BuiltInParameter.SPECIFY_SLOPE_OR_OFFSET).Set(0);
e.get_Parameter(BuiltInParameter.SLOPE_START_HEIGHT).Set(startValue);
e.get_Parameter(BuiltInParameter.SLOPE_END_HEIGHT).Set(endValue);
Here is the sample code for slope
e.get_Parameter(BuiltInParameter.SPECIFY_SLOPE_OR_OFFSET).Set(1);
double slopeValue = 45 * (Math.PI / 180); //45 degree
e.get_Parameter(BuiltInParameter.ROOF_SLOPE).Set(slopeValue);
