Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Changing the slope parameter in Floors in Revit 2023
6 REPLIES 6
ahmadkhalaf7892
532 Views, 6 Replies
ahmadkhalaf7892
  Hi Guys I wanted to ask how can I change the slope arrow in the floor From "Slope" to "height At Tail", if that is possible how can I edit the parameters "Height offset at tail" && "height offset at Head" .
Keep in mind that the floor is alread created and I have the slopearrow also created .
Floor floor = Floor.Create(doc, new List<CurveLoop> { c1 }, floortype.Id, lev.Id, true, Slopearrow, 0)
6 REPLIES 6
jeremy_tammik
I don't know whether this is possible programmatically, or how to achieve it in the UI either. One effective approach that you can take yourself to find out immediately is to perform the required modification manually in the end user interface and analyse the resulting API-accessible differences between the states before and after in the Revit database using RevitLookup and other database exploration tools:
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
ahmadkhalaf7892
Hi @jeremy_tammik ,
in the UI you just double click on the floor and select the slopearrow drawn inside the floor. I just want to change the Parameter Type "Slope" to "Height AT Tail" only and edit the parameters inside. are you sure there is no way to edit them ?
Hi @jeremy_tammik ,
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @ahmadkhalaf7892 ,
Yes, editing the slope arrow after creating a floor element is possible via Revit API.
First, you need to tell Revit whether you want to use "Height at Tail" or "Slope".For this you need to use BuiltInParameter.SPECIFY_SLOPE_OR_OFFSET
slopeArrow.get_Parameter(BuiltInParameter.SPECIFY_SLOPE_OR_OFFSET);
//"0" means height at tail
//"1" means slope
Here is the sample code for Height at tail
Floor floorElement;
Sketch sketch=doc.GetElement(floorElement.SketchId) as Sketch;
IList<ElementId> allElements = sketch.GetAllElements();
foreach(ElementId eid in allElements)
       Element e = doc.GetElement(eid);
       if(e.Name.Contains("Slope Arrow"))
           double startValue;
           double endValue;
           e.get_Parameter(BuiltInParameter.SPECIFY_SLOPE_OR_OFFSET).Set(0);
        e.get_Parameter(BuiltInParameter.SLOPE_START_HEIGHT).Set(startValue);
        e.get_Parameter(BuiltInParameter.SLOPE_END_HEIGHT).Set(endValue);
Here is the sample code for slope
e.get_Parameter(BuiltInParameter.SPECIFY_SLOPE_OR_OFFSET).Set(1);
double slopeValue = 45 * (Math.PI / 180); //45 degree
e.get_Parameter(BuiltInParameter.ROOF_SLOPE).Set(slopeValue);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
//"1" means slope
Floor floorElement;
           double startValue;
           double endValue;
Naveen Kumar T
ahmadkhalaf7892
Thank you very much Dear
jose_loaiza5W6L6
Hi, guys, I need something similar to pipe; I want to change the slope for a pipe. I'm using this code
// Get the pipe's parameter for slope
Parameter slopeParam = pipe.get_Parameter(BuiltInParameter.RBS_PIPE_SLOPE);
slopeParam.Set(0.01041667);
However, when executing the line slopeParam.Set(0.01041667) I get an error because slopeParam is readOnly, this operation Im doing when the user is drawing or updating a pipe, Have you any Idea how I can change the slope when is drawing?.
Thank you
Best regards
Thank you
Best regards
jeremy_tammik
Moral: explore optimal workflows and best practices manually in the user interface first.
The API is mostly just a wrapper around UI functionality.
Afaict from the discussions above, the slope is a parameter of the system, not the individual element. That might explain why the element parameter is read-only.
