Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Changing the end point of a curve
5 REPLIES 5
ahmadkhalaf7892
305 Views, 5 Replies
Hi Guys ,
Is it possible to change the end point of a specific Curve,if it is what is the specific method ?
5 REPLIES 5
Hi Jeremy, it's a line Curve, I have two lines that are close to each other, Line[A] and Line [A+1} I am trying to make the Line[A] have the same end point as the start point of line[A+1], any idea how I can make that ?
Thank you
Hi @ahmadkhalaf7892 ,
You can use SetGeometryCurve().
Here is the sample code
 ModelLine modelLine1;
                ModelLine modelLine2;
                Line lineA = modelLine1.GeometryCurve as Line;
                Line lineB = modelLine2.GeometryCurve as Line;
                XYZ startPtA = lineA.GetEndPoint(0);
                XYZ endPtA= lineA.GetEndPoint(1);
                XYZ startPtB = lineB.GetEndPoint(0);
                XYZ endPtB = lineB.GetEndPoint(1);
                // Get Line A endPoint and set it to startpoint of line B
                endPtA = startPtB;
                Line newLine = Line.CreateBound(startPtA,endPtA);
                modelLine1.SetGeometryCurve(newLine, true);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thank you
Autodesk Customer Advisory Groups
Rail Community
