IFC File size larger than via UI-Export
dmaral
dmaral
Hello guys,
I have written a code that export a view to IFC. Although all parameters and settings are same, the ifc file size is bigger than the file, that I created via UI in Revit.
Has anyone faced same problem?
Thank you very much!
moturi.magati.george
Hi @dmaral
You could perhaps try to use IfcZIP format to export your file. The thread below contains some insights into this.
https://forums.autodesk.com/t5/revit-api-forum/ifc-export-options/td-p/9686404
Note that the issue of IFC size was logged and for the UI export and I believe this will also be resolved on the API side.
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Large-IF...
  Moturi George,     Developer Advocacy and Support,  ADN Open
dmaral
Thank you very much! I will try IfcZip and let you know 🙂
