Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Can't select elements in a linked model
DanielKP2Z9V
DanielKP2Z9V
I'm trying to select all columns in a linked model. However this doesn't work. It correctly gets Ids of the column elements, but the final ` uiDoc.Selection.SetElementIds(columnIds);` doesn't select anything.
Any help would be really appreciated.
    [Transaction(TransactionMode.Manual)]
    public class SelectLinkedColumns : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            // Get the Revit application and document
            UIApplication uiApp = commandData.Application;
            UIDocument uiDoc = uiApp.ActiveUIDocument;
            Document doc = uiDoc.Document;
            try
                // Prompt user to select a linked Revit model
                Reference linkedRef = uiDoc.Selection.PickObject(ObjectType.LinkedElement, "Select a linked Revit model");
                Element linkedElement = doc.GetElement(linkedRef.LinkedElementId);
                RevitLinkInstance linkedInstance = linkedElement as RevitLinkInstance;
                Document linkedDoc = linkedInstance.GetLinkDocument();
                // Select all columns in the linked model
                FilteredElementCollector collector = new FilteredElementCollector(linkedDoc);
                ICollection<ElementId> columnIds = collector.OfCategory(BuiltInCategory.OST_Columns)
                                                            .WhereElementIsNotElementType()
                                                            .ToElementIds();
                // Select the columns
                TaskDialog.Show("Success", $"Selected {columnIds.Count} columns in the linked model.");
            catch (Exception ex)
                TaskDialog.Show("Error", ex.Message);
                return Result.Failed;
            return Result.Succeeded;
scgq425
Hi @DanielKP2Z9V :
u can see this solution , has code to select link element
https://forums.autodesk.com/t5/revit-api-forum/can-not-select-any-linked-element-in-revit-using-revi...
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
Mohamed_Arshad
HI @DanielKP2Z9V
      Unfortunately, we aren't able to Highlight Linked Model Elements. This feature is not available in Revit API :(.
Highlight Linked Elements discussion threat
https://forums.autodesk.com/t5/revit-api-forum/highlight-and-tag-linked-elements/m-p/5294217#M7339
A small suggestion in your code
  // You can directly select Linked Model itself, don't need to select Linked Element
                Reference linkedRef = uiDoc.Selection.PickObject(ObjectType.Element, "Select a linked Revit model");
                Element linkedModel = doc.GetElement(linkedRef);
                RevitLinkInstance linkedInstance = linkedModel as RevitLinkInstance;
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
DanielKP2Z9V
@scgq425 by select I mean to select them in the Revit UI - the same way the user selects objects in a linked model by pressing TAB and left mouse button
DanielKP2Z9V
thanks @Mohamed_Arshad, do you know where users can vote up this feature to be added to Revit API?
Mohamed_Arshad
HI @DanielKP2Z9V
     Already a threat has been raised in Idea Station and it is also accepted by the Autodesk Team. But I don't why they are not implemented still 😞  You can post your vote in the below link with a comment. Let's see 🙂
Voting URL: https://forums.autodesk.com/t5/revit-ideas/highlight-element-selection-in-linked-files/idi-p/7619701
Hope this will Help 🙂
Mohamed Arshad K
DanielKP2Z9V
Threats won't help us convince autodesk to implementing users' ideas 🙂 but thanks for sharing the link - I've upvoted it as well
By the way this is not a solution - I've accidentally pressed that button and there doesn't seem to be a way to uncheck it now
