Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Can't load RevitAPIUI.dll
8 REPLIES 8
Message 1 of 9
2832 Views, 8 Replies
Hi All,
Sorry for the repost, but I think this is the better place to ask for this.
I'm starting to write code to access Revit Structure 2012 through the VB environment in Rhino/Grasshopper. When I'm trying to reference the assemblies, I can succesfully load the RevitAPI.dll, but I can't load the RevitAPIUI.dll.
The error is: 'Import failed for 'C:\Program Files\Autodesk\Revit Structure 2012\Program\RevitAPIUI.dll': Could not load file or assembly 'RevitAPIUI.dll' or one of its dependencies. The specified module could not be found.'
It seems to look for adui18res.dll.
Any ideas what this could be? Or where to look for any errors?
Any help would be greatly appreciated!
Thank you very much!
Jeroen
8 REPLIES 8
Message 2 of 9
ollikat
Message 3 of 9
saikat
HI Jeroen
Did the links suggested by ollikat help resolve the issue? If not, do let us know.
thanks
Saikat
Saikat Bhattacharya
Senior Manager - Technology Consulting
Message 4 of 9
jeremytammik
in reply to: saikat
Dear Jeroen,
You can never load RevitAPIUI.dll yourself. Only Revit can do that. The same applies to RevitAPI.dll, actually. The Revit API only works within Revit itself.
Cheers
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 5 of 9
Hi All,
Thank you for the prompt replies. Unfortunately I wasn't able to succeed with the API outside of Revit, for the obvious reason that it's not possible.
I started writing addins for Revit directly and will use an intermediate file to transfer the information.
Thanks for your help! It's greatly appreciated!
Jeroen
Message 6 of 9
jeremytammik
Perfect! Good luck and have fun!
Jeremy Tammik
The Building Coder
Message 7 of 9
in reply to: jeremytammik
I've upgraded my Revit 2020 add in to Revit 2021 by referencing the new DLL's. The addin used to load into revit 2021 without any issues. Now I get an error stating:
I've searched the forum but haven't found a solution yet. Any thoughts?
Message 8 of 9
jeremy_tammik
Maybe you inadvertently specified that your add-in is strongly named, and that is causing it to refuse to load non-strongly-named references. RevitAPIUI is not strongly named, so your add-in referencing it cannot be so either.
Message 9 of 9
in reply to: jeremy_tammik
Thank you Jeremy for the suggestion. You are correct. I had selected to use a strongly named key file. Once I changed this it worked out. Thanks again!
Forma Design Contest
Rail Community
