Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Area of a door
10 REPLIES 10
Message 1 of 11
2082 Views, 10 Replies
Area of a door
Hello everybody,
I have a small problem. In my program, the area parameter of a door has the value is 3.189 m2 and the dimension of the door, watching the family name and checking it in the model, is 0915x2134 mm, in other words, 1.952 m2.
My question it is what does it mean the value of area parameter?. And how I can calculate the area of  door.
Javi
10 REPLIES 10
Message 2 of 11
RPTHOMAS108
I would edit the family to check how the parameter is being calculated, 'Area' is not a parameter I've seen associated with an OOTB door family.
Message 3 of 11
in reply to: RPTHOMAS108
First of all, I would like to thank your help. Unfortunately, I have not been able to understand. If I am not wrong, Area is a parameter and its internal definition defines it as HOST_AREA_COMPUTED. And the with and Height and Width are parameters associated to the Type.
Any comment will be useful.
Javi
Message 4 of 11
RPTHOMAS108
This discussion has occurred previously. Not sure what your aim is in getting the door area but perhaps the thread below will offer an alternative approach to your end goal.
https://forums.autodesk.com/t5/revit-api-forum/door-window-areas/m-p/5535565/highlight/true#M9041
I'm not sure what is being reported by that BIP, I know the things it doesn't seem to be:
Surface area of wall host within project
Surface area of host wall object within door family template
Surface area of door plus wall faces of door opening cut
The BIP isn't visible in the UI so it may be for internal use. The same parameter used with walls seems to give more understandable values.
Message 5 of 11
First of all, thank for your help. I read the post that you set down, but this is not the approach. My necessity is that I need to know the area of a door, using a parameter or a calculation using the parameters of door. Or unless, what the parameter "Area" is calculation.
Thank again for your help,
Javi
Message 6 of 11
FAIR59
You could use the boundingbox of the door to get the area.
			FamilyInstance inst;
			BoundingBoxXYZ bb = inst.get_BoundingBox(null);
			double area = (bb.Max.X-bb.Min.X)*(bb.Max.Z-bb.Min.Z);
			TaskDialog.Show("area", UnitUtils.Convert(area, DisplayUnitType.DUT_SQUARE_FEET, DisplayUnitType.DUT_SQUARE_METERS).ToString());
Message 8 of 11
in reply to: jeremytammik
Thanks for your answer. Although, I was trying to get the area from the door because I wouldn't be concern about the host. I was thinking about the area of the geometry.
Javi
Message 9 of 11
Besides, if I use your aproche, and I have understood your proposal, I couldn't find the size of each door and each window in the case there were windows and doors hosted in the same wall, because I find all opening in the wall, but not the the correspondence between doors and windows and its openings.
Yours
Javi
Message 10 of 11
A second sight, I have seen the solution in one of the links
Message 11 of 11
jwebster-RSA
You can get the area of a door on a schedule, similar to how you add window areas:
To add the area of a door to a schedule table
  1. Either open your existing door schedule - or create a new one - Click View menu > New > Schedule/Quantities. - In the Schedule dialog box, under Category, select Doors and click OK.
  2. On the Fields tab of the Schedule Properties dialog box:
    1. Select Height and click Add.
    2. Select Width and click Add.
    3. click OK.
  3. Under the Modify Schedule/Quantities tab, click Calculated.
  4. In the Calculated Value dialog box, enter Door Area in the Name box.
  5. Verify that the Formula option is selected.
  6. Discipline can stay "Common".
  7. From the Type drop-down list, select "Area".
  8. In the Formula box, enter Height*Width (you can use "..." to select each variable).
    Note: Do not include any spaces in the formula.
  9. Click OK to close each dialog box.
You should see all the door areas for scheduled doors.
Tags (1)
Forma Design Contest
Rail Community
