I have a xaml Window that is raising an External Event to load and place a new family in the active project document.
All of my xaml loads and functions correctly. When I send the UIDocument.PostRequestForElementTypePlacement(familySymbol), everything still runs correctly, the application in the background visually changes to show that it is getting ready to place a family and then I hit an exception.
System.Transactions Critical: 0 : <TraceRecord xmlns="http://schemas.microsoft.com/2004/10/E2ETraceEvent/TraceRecord" Severity="Critical"><TraceIdentifier>http://msdn.microsoft.com/TraceCodes/System/ActivityTracing/2004/07/Reliability/Exception/Unhandled</TraceIdentifier><Description>Unhandled exception</Description><AppDomain>DefaultDomain</AppDomain><Exception><ExceptionType>System.Windows.Markup.XamlParseException, PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35</ExceptionType><Message>The invocation of the constructor on type 'Autodesk.Internal.Windows.Badge' that matches the specified binding constraints threw an exception.</Message><StackTrace> at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlReader templateReader, XamlObjectWriter currentWriter)
at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlObjectWriter objectWriter)
at System.Windows.FrameworkTemplate.LoadOptimizedTemplateContent(DependencyObject container, IComponentConnector componentConnector, IStyleConnector styleConnector, List`1 affectedChildren, UncommonField`1 templatedNonFeChildrenField)
at System.Windows.FrameworkTemplate.LoadContent(DependencyObject container, List`1 affectedChildren)
at System.Windows.StyleHelper.ApplyTemplateContent(UncommonField`1 dataField, DependencyObject container, FrameworkElementFactory templateRoot, Int32 lastChildIndex, HybridDictionary childIndexFromChildID, FrameworkTemplate frameworkTemplate)
at System.Windows.FrameworkTemplate.ApplyTemplateContent(UncommonField`1 templateDataField, FrameworkElement container)
at System.Windows.FrameworkElement.ApplyTemplate()
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
at Autodesk.Private.Windows.PanelListView.MeasureOverride(Size constraint)
at System.Windows.Controls.ItemsPresenter.MeasureOverride(Size constraint)
at System.Windows.Controls.Border.MeasureOverride(Size constraint)
at System.Windows.Controls.Control.MeasureOverride(Size constraint)
at System.Windows.Controls.ScrollContentPresenter.MeasureOverride(Size constraint)
at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
at System.Windows.Controls.ScrollViewer.MeasureOverride(Size constraint)
at Autodesk.Private.Windows.PanelListScrollViewer.MeasureOverride(Size constraint)
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean&amp; handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean&amp; handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)</StackTrace><ExceptionString>System.Windows.Markup.XamlParseException: The invocation of the constructor on type 'Autodesk.Internal.Windows.Badge' that matches the specified binding constraints threw an exception. ---&gt; System.Exception: The component 'Autodesk.Internal.Windows.Badge' does not have a resource identified by the URI '/AdWindows;component/themes/badge.xaml'.
at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
at Autodesk.Internal.Windows.Badge..ctor()
--- End of inner exception stack trace ---
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)</ExceptionString><DataItems><Data></Data></DataItems><InnerException><ExceptionType>System.Exception, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</ExceptionType><Message>The component 'Autodesk.Internal.Windows.Badge' does not have a resource identified by the URI '/AdWindows;component/themes/badge.xaml'.</Message><StackTrace> at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
at Autodesk.Internal.Windows.Badge..ctor()</StackTrace><ExceptionString>System.Exception: The component 'Autodesk.Internal.Windows.Badge' does not have a resource identified by the URI '/AdWindows;component/themes/badge.xaml'.
at Autodesk.Internal.Windows.Badge..ctor()</ExceptionString></InnerException></Exception></TraceRecord>
An unhandled exception of type 'System.Windows.Markup.XamlParseException' occurred in WindowsBase.dll
The only other example I could find on the internet was listed here:
Should I catch the XamlParseException and if it is of the type Autodesk.Internal.Windows.Badge then dismiss the exception? Or should I be trying to call this AdWindows somehow?
