Missing /AdWindows;component/themes/badge.xaml
I've been having a few different problems while trying to load a plugin into Revit. The plugin worked a few weeks ago, then I added a few things and it stopped working due to multiple problems. I'm not sure if any of them are related to the others, so I'll give you a rundown of what I've changed.
First I added a reference to EntityFramework. When loading the plugin in revit, it failed to find the referenced dll. I got past that by adding an assembly resolver that loaded the dll manually. That got me past a few different dll problems. Each of these are handled by a specific case.
This is how I resolved them:
if (args.Name.Contains("Microsoft.EntityFrameworkCore"))
	string assemblyFile = Path.Combine(Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location), "Microsoft.EntityFrameworkCore.dll");
	if (File.Exists(assemblyFile))
		return Assembly.LoadFrom(assemblyFile);
//Checked for all other dlls with known issues return null;
Now that I can get the plugin to load into revit when I start it up, I hit another problem when I try to open a new project. As soon as I try to load one of the given templates (or click on the add-ins tab), I get the following exception.
System.Windows.Markup.XamlParseException
  HResult=0x80131501
  Message=The invocation of the constructor on type 'Autodesk.Internal.Windows.Badge' that matches the specified binding constraints threw an exception.
  Source=PresentationFramework
  StackTrace:
   at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
   at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlReader templateReader, XamlObjectWriter currentWriter)
   at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlObjectWriter objectWriter)
   at System.Windows.FrameworkTemplate.LoadOptimizedTemplateContent(DependencyObject container, IComponentConnector componentConnector, IStyleConnector styleConnector, List`1 affectedChildren, UncommonField`1 templatedNonFeChildrenField)
   at System.Windows.FrameworkTemplate.LoadContent(DependencyObject container, List`1 affectedChildren)
   at System.Windows.StyleHelper.ApplyTemplateContent(UncommonField`1 dataField, DependencyObject container, FrameworkElementFactory templateRoot, Int32 lastChildIndex, HybridDictionary childIndexFromChildID, FrameworkTemplate frameworkTemplate)
   at System.Windows.FrameworkTemplate.ApplyTemplateContent(UncommonField`1 templateDataField, FrameworkElement container)
   at System.Windows.FrameworkElement.ApplyTemplate()
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at Autodesk.Private.Windows.PanelListView.MeasureOverride(Size constraint)
   at System.Windows.Controls.ItemsPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollViewer.MeasureOverride(Size constraint)
   at Autodesk.Private.Windows.PanelListScrollViewer.MeasureOverride(Size constraint)
   at System.Windows.Controls.StackPanel.StackMeasureHelper(IStackMeasure measureElement, IStackMeasureScrollData scrollData, Size constraint)
   at System.Windows.Controls.StackPanel.MeasureOverride(Size constraint)
   at Autodesk.Private.Windows.PanelSetListView.MeasureOverride(Size constraint)
   at System.Windows.Controls.Decorator.MeasureOverride(Size constraint)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.Interop.HwndSource.SetLayoutSize()
   at System.Windows.Interop.HwndSource.set_RootVisualInternal(Visual value)
   at DockablePaneInterop.attachPane(DockablePaneInterop* , HWND__* parent, DockablePaneProviderData paneData)
   at APIDockableView.OnCreate(APIDockableView* , tagCREATESTRUCTW* lpCreateStruct)
   at MFCFormView.WindowProc(MFCFormView* , UInt32 , UInt64 , Int64 )
Inner Exception 1:
Exception: The component 'Autodesk.Internal.Windows.Badge' does not have a resource identified by the URI '/AdWindows;component/themes/badge.xaml'.
Any ideas for why I'm getting this exception or how to fix it?
jeremytammik
No idea whatsoever why you see these messages. I never heard of them.
Yes, I do have an idea to fix it, and I use it myself all the time.
Whenever anyone shares an add-in with me, I do not try to adapt it to run on my system.
Instead, I use the Visual Studio Revit add-in wizard to create myself a new add-in skeleton, all automatically set up and ready to run:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.20
Then I just copy the new code into its external command and external application modules and I'm set with no hassles.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
That worked perfectly! Thank you for the help
