Hide ribbon tab if family document active
juancalvoferrandiz
juancalvoferrandiz
Hello everyone,
OBJECTIVE: To hide a external application (the tab in the ribbon) when a family document is open.
CONTEXT: I understand the XML tag "NotVIsibleInFamily", but it seem to work just for external commands:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2017/ENU/Revit-API/files/GUID-...
Thanks.
Have a nice day.
Juan.
aignatovich
Hi!
You can add a reference to UIFramework.dll (it is in the same folder as RevitAPI.dll)
Then you can control specific tab visibility:
var rc = RevitRibbonControl.RibbonControl;
var tab = rc.FindTab("<your tab name>");
tab?.IsVisible = false; // or true
It can be done in ViewActivated event handler, something like:
private void OnViewActivated(object sender, ViewActivatedEventArgs e)
... tab.IsVisible = !e.Document.IsFamilyDocument; }
juancalvoferrandiz
Ok. Thanks for your answer. At this moment I don't understand events as well as I would like. When I have time to study them properly I will try your idea. Thanks again. Have a nice week.
You could also consider implementing an IExternalCommandAvailability class.  This class can be assigned to a button an will allow you to "compute" whether the button should be enabled or not.  You could check for family document there and disable the buttons (instead of hiding the tab which can lead to user confusion).
In your pushbutton data object you can set the availability class like this:
myCommandBtnData.AvailabilityClassName = "myNameSpace.myCommandAvailability";
the class looks like this:
    class myCommandAvailability : IExternalCommandAvailability
        public bool IsCommandAvailable(UIApplication applicationData, CategorySet selectedCategories)
                if (applicationData.ActiveUIDocument.Document.IsFamilyDocument)
                      return false;
If you want to get fancy, you can keep a reference to the button and change the text or tooltip to help the user understand why they command is disabled in a particular situation.
