Deleting views with a yes/no parameter
aclarke
aclarke
Hi all,
I am having some difficulty understanding an issue.  I have a list of views I want to keep by a yes/no parameter.  problem is, all views are deleted.  If I swap out the delete with a print to list, the output looks fine.  The views I want to delete are listed and the ones I want to keep are not --  the views are not dependent on a parent view but all views go bye-bye.
I have tried !v.LookupParameter(paramterName.AsValueString().Equals("Yes"))
.AsInteger(1));
Thanks for any assistance
string parameterName = "ViewUse";
List<ViewPlan> deleteViews = new List<ViewPlan>();
foreach (ViewPlan v in myFunctions.CollectedViewPlans(doc))
    if (v.LookupParameter(parameterName).AsValueString() != "Yes")
        deleteViews.Add(v);
foreach (ViewPlan v in deleteViews)
    try
        doc.Delete(v.Id);
    catch { }
TripleM-Dev.net
the line:
Checks if the value isn't "Yes", well in Revit if a parameter hasn't been used it actually doesn't have a state so for a boolean it would return No (See in Revit properties it's a grey'd box with a x in it, but reads no).
Use this instead, should work (I also always check if the variable is not Null):
Parameter Validate = v.LookupParameter(parameterName);
 if (Validate != null && Validate.HasValue && Validate.AsValueString() != "Yes")
- Michel
Sean_Page
I think you could also just take the "string" out of the equation and just use the integer value.
//Use an Element Id list and you can delete them all at once rather than iterate the list again.
List<ElementId> deleteViewIds = new List<ElementId>();
//Yes/No params have 1 or 0 as a value for thier boolean as well.
if(v.LookupParameter(param).AsInteger() != 1)
    //Add the Element Id to the list, not the ViewPlan
    deleteViews.add(v.Id);
try
    //Delete method can take a list of element Ids
    doc.Delete(deleteViews);
catch
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
aclarke
Thanks for the replies
The issue was a callout view
So we have:
'Primary View' and 'Dependent View', which is a duplicate as dependent view
and
'Parent View' and 'Child View', which is a callout view 'child' on a master plan 'parent' view
When the parent view gets deleted the child view goes with it
