AdWindows Autodesk.Internal.Windows.Badge
kraftwerk15
kraftwerk15
I have a xaml Window that is raising an External Event to load and place a new family in the active project document.
All of my xaml loads and functions correctly. When I send the UIDocument.PostRequestForElementTypePlacement(familySymbol), everything still runs correctly, the application in the background visually changes to show that it is getting ready to place a family and then I hit an exception.
System.Transactions Critical: 0 : <TraceRecord xmlns="http://schemas.microsoft.com/2004/10/E2ETraceEvent/TraceRecord" Severity="Critical"><TraceIdentifier>http://msdn.microsoft.com/TraceCodes/System/ActivityTracing/2004/07/Reliability/Exception/Unhandled</TraceIdentifier><Description>Unhandled exception</Description><AppDomain>DefaultDomain</AppDomain><Exception><ExceptionType>System.Windows.Markup.XamlParseException, PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35</ExceptionType><Message>The invocation of the constructor on type 'Autodesk.Internal.Windows.Badge' that matches the specified binding constraints threw an exception.</Message><StackTrace>   at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
   at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlReader templateReader, XamlObjectWriter currentWriter)
   at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlObjectWriter objectWriter)
   at System.Windows.FrameworkTemplate.LoadOptimizedTemplateContent(DependencyObject container, IComponentConnector componentConnector, IStyleConnector styleConnector, List`1 affectedChildren, UncommonField`1 templatedNonFeChildrenField)
   at System.Windows.FrameworkTemplate.LoadContent(DependencyObject container, List`1 affectedChildren)
   at System.Windows.StyleHelper.ApplyTemplateContent(UncommonField`1 dataField, DependencyObject container, FrameworkElementFactory templateRoot, Int32 lastChildIndex, HybridDictionary childIndexFromChildID, FrameworkTemplate frameworkTemplate)
   at System.Windows.FrameworkTemplate.ApplyTemplateContent(UncommonField`1 templateDataField, FrameworkElement container)
   at System.Windows.FrameworkElement.ApplyTemplate()
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at Autodesk.Private.Windows.PanelListView.MeasureOverride(Size constraint)
   at System.Windows.Controls.ItemsPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollViewer.MeasureOverride(Size constraint)
   at Autodesk.Private.Windows.PanelListScrollViewer.MeasureOverride(Size constraint)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
   at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
   at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean&amp;amp; handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean&amp;amp; handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)</StackTrace><ExceptionString>System.Windows.Markup.XamlParseException: The invocation of the constructor on type 'Autodesk.Internal.Windows.Badge' that matches the specified binding constraints threw an exception. ---&amp;gt; System.Exception: The component 'Autodesk.Internal.Windows.Badge' does not have a resource identified by the URI '/AdWindows;component/themes/badge.xaml'.
   at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
   at Autodesk.Internal.Windows.Badge..ctor()
   --- End of inner exception stack trace ---
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)</ExceptionString><DataItems><Data></Data></DataItems><InnerException><ExceptionType>System.Exception, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</ExceptionType><Message>The component 'Autodesk.Internal.Windows.Badge' does not have a resource identified by the URI '/AdWindows;component/themes/badge.xaml'.</Message><StackTrace>   at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
   at Autodesk.Internal.Windows.Badge..ctor()</StackTrace><ExceptionString>System.Exception: The component 'Autodesk.Internal.Windows.Badge' does not have a resource identified by the URI '/AdWindows;component/themes/badge.xaml'.
   at Autodesk.Internal.Windows.Badge..ctor()</ExceptionString></InnerException></Exception></TraceRecord>
An unhandled exception of type 'System.Windows.Markup.XamlParseException' occurred in WindowsBase.dll
The only other example I could find on the internet was listed here:
https://forums.autodesk.com/t5/revit-api-forum/missing-adwindows-component-themes-badge-xaml/td-p/82...
Should I catch the XamlParseException and if it is of the type Autodesk.Internal.Windows.Badge then dismiss the exception? Or should I be trying to call this AdWindows somehow?
kraftwerk15
The issue was because of one of the projects that is in my solution was using the RevitAPI as a reference with Copy Local on the assembly to true in Visual Studio. I had modified this at some point to Copy Local as true, built the solution, realized this was in error and changed to Copy Local as false. The RevitAPI.dll along with the AdWindows.dll was next to my .dll.
After deleting this from my Debug folder and rebuilding, I no longer get this XamlParseException.
Cheers.
