View states not visible in ACC viewer after publishing recap file
kloe.kegels
kloe.kegels
I recently started using ACC together with Recap. It seems to work fine, but for some reason in the forge viewer, the View states are not present. Even though there are view states in recap.
Is this a sync issue? Am I publishing my point cloud wrong?
barmanr
Hi @kloe.kegels ,
Are those View States created for the Real Views or 3D Views?
View States are not supported with the current version of the viewer when they are created in the 3D view in ReCap. View States are only supported for those made in Real Views in ReCap at the moment.
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
kloe.kegels
aah ok, yes that is the issue. Good to know, thank you.
david_manningQR7YW
I notice that the view states are now syncing to Forma (ACC) but are not actually trimming the view to a limit box, and is only positioning the viewpoint.
I expect that this is related to not being able to select points or use a limit box/plane in Forma.
This is functionality that is very valuable and should be added to ACC viewer.
See my related post in the Forma community here: https://forums.autodesk.com/t5/forma-site-design-developer/point-cloud-view-states-functionality-ali...
mike_deacon2KEDC
Good spot @david_manningQR7YW - you are correct.
Limit box functionality on the point cloud viewed in Forma is something that we are looking into. Thank you for the feedback on this potential feature!
