Point cloud view states functionality alignment to Recap
david_manningQR7YW
Message 1 of 1
david_manningQR7YW
The functionality to sync view states to Forma and the point cloud viewer environment have made the states available when viewing online, but it is only useful to move the camera position to the predefined location and does not change the view state of the point cloud.
I tested both clipping and limit boxes options and neither change the visibility of the points in the Forma viewer.
I expect that this is because the viewer have no function for limit box or clipping of points which is dis appointing.
Can you please add these functions to the Forma viewer and ensure that the view state of a point cloud when saved in recap matches the view conditions when viewing on Forma.
Also see post in the other forum
https://forums.autodesk.com/t5/recap-forum/view-states-not-visible-in-acc-viewer-after-publishing-re...
Replies (0)
