Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Recap Crashes during selection
freedom1k
freedom1k
this has been a persistent  Bug for years. During a fence selection, do not double-click to end selection on the 2nd pick of an area. Recap will freeze-up every time. it's a hard crash before Report window, so using this forum to report Bug. The Window Selection only requires 2 picks to form an area section, but Fence requires 3 or more clicks to form an area. 2 clicks is a line selection. the tool needs a method to prevent less than 3 clicks by accident built into software.
mike_deacon2KEDC
Hey @freedom1k ,
Can I just double check which version of ReCap you are working in? I just spent a bit of time trying to make it crash in ReCap 2027 using your steps above but couldn't get it to fail (which is good for the software I suppose, not so good for getting to the bottom of your issue!).
Let me know, might be this is fixed in the latest version *fingers crossed*.
Mike Deacon
Product Owner, Reality Solutions
