ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Recap to civil3D
16 REPLIES 16
Message 1 of 17
3173 Views, 16 Replies
Recap to civil3D
Dears, I am using the Autodesk Recap Pro version 4.0.0.28 to edit a point cloud fille generated from image processing using the PIX4d mapper pro.
When i deleted part of the points and attach it to the Autodesk civil3D 2018 version 12.0.842.0 the location is correct as was previously when the point cloud file was complete and unedited.
16 REPLIES 16
Message 2 of 17
anil_mistry
Hi @Anonymous,
Are you saying that when you import Point Cloud into Civil 3D its not supposed to align correctly? I am but confuse her. Would you be able to provide detail information or workflow to understand this behavior better?
Thank you and have a great day!!!
Anil Mistry
Technical Support Specialist
Message 3 of 17
in reply to: anil_mistry
Hi Anil,
Thx for your replay, i when i attach a point cloud file from recap to civil3d and when i delete part of it and attach it again to civil3d it is not coming to the correct location (check the attached pdf)
Regards
Sabbagh
Message 4 of 17
anil_mistry
Hi @Anonymous,
I am unable to duplicate this behavior on my end. I did following:
1. Create new ReCap Project
2. Import RCP to Civil 3D
3. Open ReCap Project, delete some point
4. Save As different name
5. Import New RCP to Civil 3D
6. Both RCP align correctly.
Please, let me know if you are doing above mention workflow? Would you be able to record (screencast) of this behavior and share with me to investigate this further.
Anil Mistry
Message 5 of 17
Dear Anil,
The workflow that I am following:
1-Open empty Civil3d
2- From Insert->AutoCAD Point Cloud->Attach- the complete .rcp model:"AUB1_import Civil3d1.rcp"
3-From Insert->AutoCAD Point Cloud->Autodesk Recap->opened the "AUB1_import Civil3d1.rcp"-delete part of the model and save it in another name :
"AUB1_import Civil3d1_oneBldg.rcp"
4-From Insert->AutoCAD Point Cloud->Attach- the complete .rcp model:"AUB1_import Civil3d1_oneBldg.rcp"
5- in the civil3d file "AUB1_import Civil3d1.dwg" the two .rcp are not align correctly.
I attached the civil3d
Thank you very much
Regards
sabbagh
Message 6 of 17
anil_mistry
Hi @Anonymous,
Thank you for sharing Civil 3D drawing but this file is missing point cloud data. Would you be able to share your ReCap project with supporting files?
If you can then let me know and will send you BOX invite.
Thank you and have a great day!!!!
Anil Mistry
Message 7 of 17
Hi Anil,
I tried to upload the .rcp files without success, please send the Box invite
Regards
Sabbagh
Message 8 of 17
anil_mistry
Hi @Anonymous,
I just send you BOX invite. Please, upload RCP and Supporting folder and let me know once its done uploading.
Anil Mistry
Message 9 of 17
Hi Anil,
I couldn't upload the two .rcp files to the Box, can you send me you mail to share it with you .
Regards
Sabbagh
Message 10 of 17
anil_mistry
Hi @Anonymous,
Thank you for sharing RCP files. Can you upload Support Folder for these projects to A360 project drive as well.
Thank you,
Best Regards,
Anil Mistry
Anil Mistry
Message 11 of 17
OP,
If you're cropping in ReCap, then re-indexing upon export, you will need to make sure your coordinate zone is set and your origin is in the same location as it was before it was cropped.
It sounds to me like the origin is being misplaced upon crop.
Another option is to crop within Civil 3D using the temporary crops, or by turning scans on or off by using the point cloud manager (POINTCLOUDMANAGER) for an indexed scan.
Message 12 of 17
Dear Henry,
You mentioned the following : "you will need to make sure your coordinate zone is set and your origin is in the same location as it was before it was cropped. "
can you share with me an explanatory resource.
Regards
Sabbagh
Message 13 of 17
Hi Anil,
Any updates?
Regards
Sabbagh
Message 14 of 17
anil_mistry
Hi @Anonymous,
Sorry I don't have any update on this. I send you message requesting to upload ReCap project support folder for further investigation. RCP that you shared is no good without support folder. Also, have you tried suggestion that was posted by @Anonymous. Please, let me know if that helps.
Anil Mistry
Message 15 of 17
Here's an explanation on where you can set the coordinate system:
ReCap Import Settings
If you change the origin, then export, your coordinate system will be thrown off.
Here is a link to an explanation about working with point clouds inside of AutoCAD (or any other vertical product):
About Working With Point Clouds
Hopefully you'll find what you're looking for there
Message 16 of 17
Hi Anil,
What is "ReCap project support folder " ?
Regards
Message 17 of 17
anil_mistry
Hi @Anonymous,
Support folder supporting RCS files to view project. If you navigate to your project location in Windows explores you will see support folder with project name which contains several supporting files.
Anil Mistry
Rail Community
