Mirror Balls in 3D view
Message 1 of 11
Hi
I Encounter the same promblem as a post from 2016-01-04 where the mirror balls disappear from my normal 3D point cloud view. I Have the latest version of Recap installed (4.0.0.28). I have registered this project on my laptop, and opened the project and all was well. When i opened the project later again, the mirror balls were missing. If i Click on the realview icon, then i can see the mirror balls again, but as soon as I go to the point cloud view they disappear.
Any ideas anyone.
Thanks very much.
Replies (10)
Message 2 of 11
Ok.
I dont know how, but the mirror balls are back now. I just saved the project again, adjusted the limit box, then confirmed and then reset the limit box again and then the mirror balls came back.
Message 3 of 11
Hi all,
We have same problem.
I have just one mirror ball on 300 scans....
What is the solution ?
Thanks in advance
Flo
Message 4 of 11
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Please, try deleting content from Project "Temporary Cache Files" folders and try opening project again. This folder is located under project support folder.
Let me know if this helps.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 5 of 11
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 6 of 11
Hi.
Im sorted now thanks very much
Message 7 of 11
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am glad to hear that the issue is now resolved. Please, let me know if you have any other questions or concern.
Anil Mistry
Message 8 of 11
Same problem....
Delete "Temporary Cache Files" don't work...
help....
I think your last update have a problem with realview/mirrorballs
Message 9 of 11
Patrick_Aps_9121
It can also depend on which kind of cloud you have opened.
1) Some file types are not structured, like PTS, and result in not having a Mirror Ball in the 3D view.
2) If you export "the regions of a Project" or "a complete project" with balls into unified RCS file(s), you loose the Mirror Balls also.
Message 10 of 11
I know that...
But sometimes I have realviews sometimes no in the same project.
You have a bug i think
Message 11 of 11
eric.guizzetti
Are you talking about the folder in %tmp% or another place?
