How to use Georeferencing using survey points in ReCap Pro
I Have 7 points on the first scan, I also try to georeference but when I return to the project nothing happens.
Please someone post the workflow on how to georeference a point cloud with REAL coordinates taken by total station.
I believe this method is widely documented if you search for it
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community!  Please, click on these link to learn more about:
Let me know if this helps.
Thank you and have a great day!
Please select the Accept as Solution button if my post solves your issue or answers your question.
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
subsKL4JM
For what it's worth, I'm having the same problem as the OP. I've followed all the official documentation, including what you've linked to above, but no matter what I do, after I select all the points and match them up with my survey control points/coordinates, the point cloud remains in arbitrary coordinates, rather than absolute coordinates.
subsKL4JM
Ah, the trick is to set the right coordinate system during scan import (it's hidden in the advanced tab). Then things work. This isn't mentioned in any of the documentation - I found it by chance and through trial and error.
josip_zdrilicE5DGA
Community Visitor
Community Visitor
that is a very helpful comment
